Sharp aquos lc-37d43u tv
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light flashes but nothing at all on the screen
  • 7 more comments
  • fanyp Dec 09, 2007
    The night before, the tv was working fine. Woke up next morning, power and OPC lights flashing: both lights flash once and then power light flashes twice. Called Sharp customer services and they told me that if thos lights are flashing, something inside the tv is broken and you got to get it repaired... we'll see what it is...
  • Anonymous Jun 10, 2008
    oome on pc light is flashing tv wont come on
  • jtwicce Aug 02, 2008
    tv wont turn on green opc and power light fash together twice and then the opc three times by its self.
  • jboehm40009 Nov 06, 2008
    power and opc lights flash once together and then power light flashes twice.
  • ashdr3 Nov 28, 2008
    The red light flashes to green when the power button is pressed, then turns red and nothing comes up on the screen...
  • Anonymous Jan 22, 2009
    I have the 46" Sharp LCD TV.  Worked fine, beautiful picture and sound ... but a few times, I've put it on first thing in the morning - the power light went on, but the OPC didn't ... and the screen was blank. It took me 15 minutes to get it back on again. Wondering if I should return this before the 30-day policy is up...
  • Kevinlamail Mar 08, 2009
    I have a sharp aquos lc-32da5u tv. When I turn tv on power led light flashes and opc light flashes on and off. No picture or sound. TV is only 3 yrs old
  • randylad79 Apr 02, 2009
    My Sharp Aquos is having the same problem, when I turn on the unit, the power light comes on with a delayed click, then the power light and opc light flashes 3 times with no power going to the screeen.
  • Anonymous May 02, 2009
    Ditto: OCD power indicator light flashes three times. Nothing on the screen at all.
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
Posted on Jan 01, 2009
    Problem Solver:
  • 7 Answers
I've read online that upgrading to the latest firmware sometimes resolves this issue. That's kind of shooting in the dark though - I personally would not feel completely confident that a FW flash would actually resolve the issue (as it could still be lurking beneath somewhere, waiting to surface again). If you have no warranty, then the FW flash is not a bad option. It's relatively easy and virtually impossible to screw up!
Another option is to order a replacement (new or used) main power board, and swap it into the TV (or pay someone to do it). It seems the power circuit board is a common culprit for this issue. If you're a do-it-yourselfer, then open up your TV and see if you can tell which component is failing, then hit eBay for a replacement:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=sharp+power+board&_sacat=See-All-Categories
However, if you're still under warranty, then I imagine you've figured out by now that your best bet is to contact Sharp to fix this issue. Mine was luckily under the extended (15-month) factory warranty when this started happening to me. I was 13+ months out from date of purchase. Sharp support confirmed a tech needed to come out for an all-day appointment to troubleshoot the TV (I have the monstrous 65" Aquos). Thank goodness for the extra 3 month warranty I got when signing up for the Aquos Advantage club! Otherwise, my $3400 investment might have cost me at least $700-$800 to stay online - only ONE year out from purchase! If I would have known about the frequency and common nature of this problem, I would not have hesitated on buying the additional 3-year protection during my first year as an owner. Now I know to research product defects a bit more before opting out of a warranty for a multi-thousand dollar purchase!
In any case, I'll post the root cause of my issue (same symptom - OPC and power lights flash three times, then pause, and repeat indefinitely until TV is unplugged), once the Sharp tech leaves my place this coming week. Keep in mind that my root cause may not be the same as yours, even though the error codes are the same. :)
Good luck with your issue!
Posted on Dec 27, 2009
The solution to this problem ...and i think most of everyone's problem is that when purchasing a set ,you do not get certain help documents to ensure your not just messing something up so a tech is needed , with that said , you need to update your firmware (software). this may sound dumb ,but it works ..get a flash drive (2g and under).format it in a FAT partition only.no one has been informed about this unreleased info ..copy your files to this and go by the manual ..this is failsafe .
Posted on Jan 20, 2010
I had the same flashing power/opc light problem, with my tv freezing and going black. My signal is OTA via an antenna. Turns out, channel seven was the only one having the problem, so I'm assuming there was a problem with the signal. I've also periodically had problems with channel 9. Try another station.
Posted on Feb 02, 2010
I have two Sharp flat screens one is 2.5 and the other 3.5 years old. Both died last night. We were at dinner and came home there was a storm while we were out. We have a third TV and it is fine. We are unable to turn the power light on both of the sets - dead. We bought a new TV and it is working fine where the dead was placed. We have ComCast cable and did not have a cable box. What do you suggest - should we put them into the trash or try and get them repaired.
Posted on Jun 08, 2009
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
TV wont turn on. No sound or backlight. The OPC and Power LED's flash in tandem but when the power button is pressed it wont turn on.
There is a problem with the standby section of the power supply. A flashing standby light indicate an overload which is caused by a shorted semiconductor in that circuit. It's fairly simple for a technician and should not cost much. You can't do that yourself it is electronic takes a long time to grasp.
Jun 04, 2011 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
4,452 people viewed this question
Top Televison & Video Experts
