Question about Fedders AEQ07F2BG Air Conditioner
How do i install fedders a/c ? - Fedders AEQ07F2BG Air Conditioner
    Champion:
  • 363 Answers
The brand does not matter ,the process for instlling any window unit is the same only the sizes are different. And the power supply are different. Rule of thumb on power supply up to 12000 btu 120volt 20 amp dedicated electric circuit. over that requires 240volt circuit 30amp breaker dedicated line. As far as installation the window you chose to install the unit is MUST be within six feet of the electric outlet.Remove the casing from the main unit, I assume you have windows that you can raise up. put the leveling and side panel components on the casing, have someone help you. Place the casing in the window centered in the opening. lower the window until it is behind the top flange of the casing, screw the casing to the windo sill, lower the leveling screws until the unit is tilting toward the outside . insert the weatherstripping over the casing and lower the window as far as it will come down behind the casing flange. extend the side panels to the window casing and secure if necessary. Insert the main unit in the casing and push it all of the way in. make sure there is not any air leaks around casing or side panels. if you have done the electrical work or have had someone do the electrical work then plug the unit in, turn on the circuit breaker that is dedicated for that unit. read your startup directions and you are ready to go.
Posted on Aug 01, 2009
Looking for replacement of Fedders model T1A10W7A (not sure if installed in a type a or b sleeve). Which model can I replace with?
I suggest that you measure the sleeve's dimensions and shop the a/c dealers. They should be able to match you up with something of comparable BTUs, but more efficient.
Aug 24, 2013 | Fedders AZ7A12W7A Air Conditioner
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
I can't find the window adapter and hose for the portable Fedder #A6P09S2b.Any suggestions?
Cut a piece of plywood to fit your window opening, install a flex connector ductboard%20collar.jpglike the one shown here, and use flexible duct to connect to your unit and the connector you attached to the plywood. flex-duct.gif
Mar 19, 2010 | Fedders SFPEB08F2A Air Conditioner
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
How do i install my fedders aeq07f2bg ?
in a window with outside tilted slighty down to drain
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Fedders AEQ07F2BG Air Conditioner Logo
99 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
