Question about Magic Chef MCM660A Microwave Oven
WATTS What is the wattage of this microwave, and is it considered to be low, medium or high wattage?
  • Magic Chef Master
  • 8,803 Answers
The output power is 1000W and that's near the high end for a consumer microwave. Hope this helps.
Please write back with more details if you need further help.
We do appreciate your very thoughtful rating of our answer.
Posted on Nov 25, 2007
0 characters
3 Points
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
I want to know how many watts my 2002 jvm1430bd002 microwave has...I have googled this question and have answers ranging from 700 to 1200! what gives???
Conduct what the USDA Food Safety and Inspection Service calls a "Time-to-Boil" test, which will help you estimate your microwave's wattage. Add 1 cup of water to a microwave-safe 2-cup measure. Add ice cubes and stir until the water is icy cold. Pour out the excess water, leaving just 1 cup. Place the measuring cup inside the microwave. Set the oven for four minutes on high. Watch through the glass to see when the water boils. If it takes less than two minutes, the microwave is 1,000 watts or more; if it takes 2.5 minutes, the oven has a rating of 800 watts or more; if it boils in 3 minutes, the estimated wattage is 650 to 700.
How to Find Microwave Oven Wattage eHow
Jan 08, 2015 | Microwave Ovens
Wattage for mc 1000b microwave
By the name I would think that it is a 1000 watt Microwave. Wattage as in cooking power is what you wanted? Running wattage, a 15 amp circuit will work fine. A 120 volt, 1000 watt microwave will use 13.4 amps (1,600 watts) of electricity in a full power cooking cycle. I think that covers everything! ..:)
May 16, 2014 | Magic Microwave Ovens
Sanyo em-c 1800 sparking inside at top
That's not good at all....
check to make sure there isn't any food at the top of the microwave, also, if your microwave allows maybe try turning down the wattage when you cook such as cook on medium or Low wattage.
Also, you may need to just get a new microwave.
Oct 28, 2012 | Sanyo EM-C1800 Microwave Oven
My country use the 220 volts system do have to use a step down transformer of plug it in has been a year i have not used the appliance having no information on wattage
If your microwave is wired for 220 volts AC and your country standard house current is 220, and the plug is of the proper configuration, plug it in.
Standard microwave size is around 1100 watts at 110 volts Normally, two times the voltage is 1/2 the wattage. Ohms law, Voltares Law and Watts Law apply.
If your microwave is 1100 watts at 110 volts --- yes you will need a step- down transformer of some type.
Jul 12, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Power on, everything sounds & looks normal but not heating food. When I hit power level option it does not say high, medium or low any longer.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Oct 03, 2010 | GE JVM1850 1000 Watts Microwave Oven
Microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Jul 10, 2010 | GE JES735WJ Microwave Oven
How many watts on my microwave?
The wattages of your microwave is 800 watts.
Jun 15, 2009 | Emerson MW8985W Microwave Oven
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Goldstar MA-782M Microwave Oven
Magic Chef MCM660A Microwave Oven Logo
200 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
