Question about Samsung HL-P5063W 50" Rear Projection HDTV
No picture after replacing color wheel
Hello! I have a Samsung HL-P5063W and it's not functioning. It was making a high pitched noise and I determined that it was the color wheel. I replaced the color wheel today and now there is no picture. After turning on the TV, I can hear 3 clicks, the speakers pop, and the Lamp light flashes.
I have disassembled and reassembled several times to make sure all the connections are good. Prior to replacing the color wheel, audio and video were working fine. Should I replace the lamp next? Thanks for any assistance!
Ed
    President:
  • 3,130 Answers
Every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Posted on Aug 01, 2009
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
No picture new lamp, high pitch squeele sound
It sounds like the color wheel is beginning to fail and needs to be replaced. I would recommend calling Samsung at 1-800-samsung to find the nearest authorized service center. Trying this repair on your own can be tricky so you should let an pro take care of this one. Color wheels are around $130.-$150.00. plus labor.
Jun 16, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
The picture wont appear, i get sound but the fan seems to be having trouble and th picture wont appear
A bad fan will keep the machine from producing an image but I suspect it is a bad color wheel. When color wheel fails, you may hear a high pitched whine and no image. No image can also be caused by a burned out lamp, bad ballast or power supply board. You can call 1-800-samsung to find the nearest service center.
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung DLP TV is making a noise that sounds like a bad fan.
This high pitch noise comes from the color wheel. Now is unbalanced and the noise is going to be even hardest with the time. send it to change now. this part is inside the light engine
Dec 26, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
219 people viewed this question
Jerry Greenberg
Jerry Greenberg
