Where is the fan? The TV is a UN65JS9500 and I have looked a number of tear down videos and it is not at all obvious where it might be hiding. If it is buried and requires extensive tear down I might just let someone else do it. If it is within easy reach, I am sure I can handle it.
SOURCE: Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the process to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
SOURCE: Moving extention number
you must change the number by programing the PBX or phisicaly change the jack in the PBX.Both solutions must be done by authorized personal.check who is serviceing your pbx and make a request.
SOURCE: Checked all the obvious, everything still slow.
go to run and type msconfig>>>>disable all services other then microsoft......restart and check
SOURCE: How do you hide unwanted channels on new 4k panasonic tv
It has a parental control.. use your owners manual
