Question about Fedders AEQ07F2BG Air Conditioner
How do i install my fedders aeq07f2bg ? - Fedders AEQ07F2BG Air Conditioner
  • 154 Answers
In a window with outside tilted slighty down to drain
Posted on Aug 01, 2009
What does the air exchanger do?
Pulls in some outside air as it runs to bring in fresh.
Sep 12, 2011 | Fedders AEQ07F2BG Air Conditioner
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
Is there a drainage tube or does it drain from the corners? on the fedders aeq07f2bg
Probably out the corners. The unit needs a big old puddle of water so the slinger blade can help cool the condenser coils. If the unit is tilted towards the inside of the hoscienda then water will come inside and will be spitting out of the evaporator. That ain't too cool (pardon the pun). You would need to reposition the unit so that the water will flow towards the rear of it.
That way the agua will disperce outside. Do not drill a hole or run a wire into the unit as that could bust the sealed unit. Not good.
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
On the fedders aeq07f2bg is there a drainage tube or does it drain from the corners ?
most newer a/c units have a weep hole or drain port on the bottom of the unit, some have a place where you can hoopup a drain line.
How do i install fedders a/c ?
the brand does not matter ,the process for instlling any window unit is the same only the sizes are different. And the power supply are different. Rule of thumb on power supply up to 12000 btu 120volt 20 amp dedicated electric circuit. over that requires 240volt circuit 30amp breaker dedicated line. As far as installation the window you chose to install the unit is MUST be within six feet of the electric outlet.Remove the casing from the main unit, I assume you have windows that you can raise up. put the leveling and side panel components on the casing, have someone help you. Place the casing in the window centered in the opening. lower the window until it is behind the top flange of the casing, screw the casing to the windo sill, lower the leveling screws until the unit is tilting toward the outside . insert the weatherstripping over the casing and lower the window as far as it will come down behind the casing flange. extend the side panels to the window casing and secure if necessary. Insert the main unit in the casing and push it all of the way in. make sure there is not any air leaks around casing or side panels. if you have done the electrical work or have had someone do the electrical work then plug the unit in, turn on the circuit breaker that is dedicated for that unit. read your startup directions and you are ready to go.
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Fedders AEQ07F2BG Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
