Question about Sony STR-DG510 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Posted on Sep 21, 2009
    Novelist:
  • 154 Answers
HDMI cables carry both audio and video.
Posted on Aug 01, 2009
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Im having a hard time getting audio useing the hdmi ports on my sony str-dg520
The HDMI on this receiver is for video pass through only. It basically only serves the same purpose as an extension cord for an HDMI cable that's too short.
For audio you need to connect either a digital coax, an optical or composite cables.
Aug 25, 2010 | Sony STR-DG520 Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Jan 19, 2009 | Sony STR-DG510 Receiver
Sony STR-DG510 From component to HDMI
You have to use the same connection in and out. You can not mix inputs and outputs (Example- HDMI IN will not play on Component out and Vice Versa.)
Nov 18, 2008 | Sony STR-DG510 Receiver
No video output using either HDMI or component video
Make sure that these inputs are enabled. I'd have to confirm within the manual, but I believe that these have the HDMI section disabled by default.
Dan
Mar 21, 2008 | Sony STR-DG510 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Sony STR-DG510 Receiver Logo
696 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
