If it's an older mechanical machine, it probably needs a good cleaning and oiling. However, there could be other things wrong with it.
Wheel on right side that controls the needle up and down is very tight...
SOURCE: Needle touches a metal part and makes a weird noise!
Check your bobbin...make sure the handle is pointing upward.
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
SOURCE: I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
SOURCE: Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
