Question about Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00
Vehicle dies every here and now when starting cold and put in gear. Engine will start, once you switch to reverse or drive, it simply dies. After an incident like this it seems to sputter for a few seconds, then drive just fine...any clues...took it to a shop, no answer, no check engine light...fuel filter replaced 4 months ago...
    Sergeant:
  • 190 Answers
Sounds like it may not be idled high enough or you have a bad vaccum leak
Posted on Aug 01, 2009
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Car will start but put it in gear engine will die
engine starts with no problem; but, when I put in gear and ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusNov 15, 2012 - The engine just fall dead when you step on the gas; it seems to jerk before ... My car does the same thing but i put it in neutral n it starts up. ... I have a 2004 kia optima it jerks when I go into reverse it was driving ... start and run fine butwhen I put it in drive or any other gear it dies! ... 2002 Hyundai Elantra GT.
Engine stalls when tranny put in Drive or Reverse - Kia Forum
www.kia-forums.com/kia-carnival...2002.../43407-engine-stalls-when-tr...
Feb 28, 2008 - 10 posts - ‎3 authors
Give it a little gas before putting in D or R and it will go. .... When I start the van cold and shift the tranny into drive or reverse.....the whole front ... won't run in forward gears - Kia Forum
May 25, 2012
Intriguing problem - engine rough idle & hesitation ...
Aug 31, 2011
2006 Kia Spectra engine stalls and bad idle, cleaning the ...
Aug 30, 2010
2002 Kia Spectra Won't Go Out of Park - Kia Forum
Oct 28, 2008
More results from www.kia-forums.com
Dec 17, 2015 | 2002 Kia Rio
Battery fully charged, engine won't start or even turn over, gear locked in park, brake pedal is depressed.
This may help: http://www.toyotanation.com/forum/274-2nd-generation-2004-2010/199861-04-sienna-transmission-lock.html
There are multiple issues here.Won't crank? Go direct to starter.
Possible recall:http://www.toyoheadquarters.com/threads/2004-2005-2007-2009-toyota-sienna-shift-lock-solenoid-recall-d0r.206/
Nov 10, 2014 | 2004 Toyota Sienna
1995 Ford Bronco engine dies when shifted into drive but runs in reverse or 1st gear
Could be fuel filter,air filter,tune up,wires,coils.low idle too low.
Jun 13, 2013 | 1995 Ford Bronco
1997 Carolla- engine dies when shift to reverse or drive, starts again when put in park. Is this a transmission problem or starter/ignition problem?
There is a switch that only only allows you to start the engine in Park or Neutral. It sounds as if yours is faulty or has a bad connection. Finding it will be the problem.
Jun 19, 2017 | 1997 Toyota Corolla
Engine starts only in neutral. when placd in
I'd be replacing neutral safety switch at transmission.
May 18, 2009 | 1997 Mercury Cougar XR7
Engine dies when shift into gear.
This sounds like the kick stand switch is bad or not making full contact.
Please take time to rate this a fixya
May 11, 2009 | 1999 Honda GL 1500 SE Gold Wing
Engine dies when put into Drive
When the vehicle is put into reverse. The transmission is working in 1st gear. The valve body and solenoids are working as designed.
When you change to Drive , The valve body could be getting stuck.
The transmission is starting our in a higher gear. Such as 3rd or over drive. There is to much torque for the engine to continue to run and is shutting down. Another possibility is the Torque converter has a lock up mode for when you are traveling down the highway.
This also can be stuck in that mode. I would take it to a local transmission shop for complete Diagnosis
Feb 01, 2009 | 1988 Ford Bronco II
1993 FORD CROWN VICTORIA has no reverse gear when engine warm.
No band for reverse,sounds like you have a trans. in need of repair.
Jan 22, 2009 | 1993 Ford Crown Victoria
Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00 Logo
89 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
