SOURCE: I own a Samsung DMR77
I had the same problem. Mine also 2yrs old. Issue started when washing dishes and it did not complete the grind and drain cycle. I tossed in 3 efferdent tablets that I use to clean all kinds of household grim with; that stuff works great on thermos mugs so I figured it might work to clean out any cloggings here too. It sat for about 15mins and then I tried to drain it again and it finally unclogged itself and now it works fine again. Probably something is getting clogged and not self-cleaning. I tried to completely disassemble the insides afterwards and you do not want to know the junk I found lingering under some of these parts which was not a good sign for the engineering group who designed this thing. Anyways I cleaned everything best I could but the issue came back a month later now again. I'm thinking it is in the pump. I plan to disassemble the pump and check it out because it too has been making a lot more noise than it did originally - its fighting something - and maybe going bad. Looking at the parts online with a new pump being around $200 its probably not worth the risk. I'll buy a new washer before I invest that much. Probably go back to my fav Kitchenaid - that was a great washer; never had an issue and it had a grinder too but was more expensive. Hope the efferdent idea gets you going again.
SOURCE: I have a Samsung dishwasher
Try waiting it out - some dishwashers like to run a rinse first to get off the easy stuff, then it starts the wash cycle. Let it run it's cycle and see if it works.
SOURCE: samsung dishwasher model dmr77 runs for 3 mins
Hello, kurt
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
SOURCE: where is the fuse for the samsung dmr77 dishwasher
Hello Margaret;
My name is Peter. I am a retired field service appliance technician.
Unfortunately, Samsung does not design their appliances to be maintenance friendly. You have a inline fuse that is in the wiring harness, inside on the on the bottom right hand side.
Substitution: Part Number 3601-001197 Cost: $4.00
You have to remove the right lower side panel to access the harness. The side panel is held on with one screw. Then pull toward you to remove.
There are several reasons your dish washer will not run.
You could have a bad door contact switch:
Remember to turn the power off first.
You could have a bad door contact switch, or one of many other sensor.
Tell me what the problem is. Is your control panel lit up?
