Question about Garden
I have a echo leaf blower mod#BP403T IT DOES NOT HAVE ANY SPARK
I have a echo leaf blower mod#BP 403T IT DOES NOT HAVE ANY SPART I CHECKED THE GROUND SWITCH TO AN OHM READIND IT READ 174 GOUND SWITCH IS GOOD CAN YOU GIVE ANY MORE IFO
  • 162 Answers
Could be rust build up on the magnito
Posted on Aug 01, 2009
How do i adjust the carb on an echo blower
Not sure what carb you have..You should be able to see a spring loaded air/gas adjustment screw on the carb..once running turn clockwise until motor starts bogging down then the other way until it does the same..keep adjusting back and forth unti it runs smooth..
you may have another on the bottom of the carb bowel..do the same with it...if this doesn't work needs a rebuild kit..good luck..
Sep 27, 2014 | Echo Pb-403T Leaf Blowers
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Where do you find the serial number of a echo PB403T
Model and serial number are underneath the recoil starter, on the engine block. Tip the blow on it's non-engine side and look right above the tank from underneath the blower.
Nov 04, 2013 | Echo Pb-403T Leaf Blowers
Primer bubble dose not fill with gas
is it cracked and are the fuel lines going to it cracked
Aug 25, 2012 | Echo Pb-403T Leaf Blowers
Ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Nov 29, 2009 | Echo Garden
No spark in my echo 4600 new spark plug tested screw driver to casing no spart how do i test the magneto or do ou have any other solutions thanks
You need to get a spark checker tool. What you do is you connect the tool to the spark plug while it is screwed in and then connect the other side of the tool to the spark plug wire. There is a light in the tool that will flicker when you pull the starter cord if there is good spark.
You can get a spark checker at any autoparts store, Harbor Freight, Northern Tool, etc.
Once you have checked for spark, if you see the light flicker and it still doesn't start, come back here and I will take you through further troubleshooting.
Nov 01, 2009 | Echo Pb - 413t Backpack Blower
Echo Blower PB-403T will not start. I replaced the air filter, fuel filter and spark plug. The fuel line inside the gas tank had broken off at the top. I reconnected and it still will not start. Previously...
Should be two fuel lines coming from fuel tank grommet. One feeds the carb's primer plate and the other returns from the same. Open the fuel tank and observe while pressing the primer. If you see fuel pumped INTO the tank while pushing the primer and pulled FROM the tank when the primer is released, you're OK. If not, the lines are backward. Filtered line is on SUCTION side of primer bulb. Unfiltered line is on PRESSURE side of primer and is simply a return to the tank.
Next, concerning the coil: Air gap should be .010 inch at the magnet. Echo ignition coils are warrantied for life to the original purchaser, so don't tamper too much with it. Check gap and check fire with a spark tester. If no spark with switch in on position, take it to an AUTHORIZED SERVICING dealer, found here.
Hope this helps,
Dolf-
Oct 15, 2009 | Garden
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
