Tablets & eReaders Logo
Hantie Roelofse Posted on Apr 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tablet UI system has stopprd whst can i do
Jeff Bird
Level 3:
  • Tablets & eR... Master 1,348 Answers
  • Posted on Apr 22, 2018
Jeff Bird
Level 3:
Answers
1348
Questions
0
Helped
362843
Points
4615
Hi try this. Cheers
My tablet UI system has stopprd whst can i do - img_20180422_195103-b1eirrwaet5bt2dc2gxaf0ac-1-0.jpg
1 Related Answer
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Mar 04, 2015
SOURCE: I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
My dell tablet has : Unfortunately, System UI has stopped. Haw can I fix this?
if your have faced this issue while using your computer. Then you need to follow these steps to fix UI Failed to Load on windows
https://www.mygeekshelp.com/avast-ui-failed-to-load-after-windows-10-update
How do I fix my proscan tablet the system ui has stopped
You need to reset using a pin inserted in the hole in the back. Pressing multiple times as deep as 1 inch
Wt is [unfortunaly, system ui has stopped working
Your android is running on low memory. Transfer some files to sd card or delete unnecessary files. Also clear data of applications at 'Manage Applications' on your menu.
1helpful
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
2helpful
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
