SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
SOURCE: I have a Scotts Basic
Start with #3 setting. You will be fine I have same spreader.Good Luck..
Testimonial: "Thank you for the help. I had pretty much settled on the 3.25 setting after reading the back of a Scotts Turfbuilder 17 lb. bag of similar ingredients"
SOURCE: I just bought a new
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
SOURCE: Trying to figure out the
You can safely use the recommened settings for the SpeedyGreen in your Scotts Basic Spreader.
Hilary @Scotts
