SOURCE: Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
SOURCE: how do you change the cutter blade on the TB Chipper?
I just did one!
There are two opposing threaded holes next to the shaft.
Screw in bolts and use a wheel or gear puller to remove.
You can use a socket that fits in the center bore for an extention of your gear puller.
auttozone or ayto supply rents for free w/deposit
