Question about XO Vision XOD1742BT Car DVD Player
Parking brake bypass
How do i bypass the parking brake for a DUAL XDVD9101. try'd the code thing it never worked dont know if im doing it right can u help me
    Problem Solver:
  • 5 Answers
The 9101 was built so you can not bypass it
Posted on Sep 04, 2009
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I just bought a dual xdvd9101 indash dvd player and cant get the brake bypass to work
However, some units use different methods. Some require seeing a pulse (i.e., power-ground-power-ground-etc.), resulting in the annoying need of pushing the e-brake a few times before your video will pop up. This can generally be recreated by using a 3-prong switch (you can get one at AutoZone). Connect it backwards -- the ground to power, power to ground, and the "Load" to the Parking Brake wire on the back of the radio. Flip the switch back and forth a few times and sometimes the video will pop up.
Some fancier units cannot be cheated. They use an internal gyro mechanism that detects movement.
Some even feature bypass codes. By pressing a certain combination of buttons on the remote then entering in a code it will permanently allow video.
Be good.
Dual DVD
Play Dvd for few seconds until you hear sound
Press Stop Twice
Then enter on remote 26604 the press enter
Nov 15, 2009 | Car Audio & Video
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
Bypass break switch
Yes, this unit will work with a toggle switch.
Aug 10, 2009 | Jensen VM9510 Car DVD Player
Dont know how to bypass e brake on a dual xdvd9101
you need to buy a switch that u can use to bypass the brake. you have to run it to the wire that you are suppose to run to the brake and you will have to switch the off and on button and then your tv will work without the brake.. i had to do it to my same exact TV..
May 15, 2009 | Dual Car Audio & Video
I need help to bypass the brake with my Dual XDVD9101
did you try connecting the bypass wire to the ground wire?
Apr 22, 2009 | Car Audio & Video
Isn't there a way to bypass the parking brake so my video plays anytime i want how to bypass parking brake(not hooked up in a car) DUAL XDVD9101
it is illegal to do that you know but simply removing the sensor wire or attaching sensor wire to ground.
Apr 13, 2009 | Car Audio & Video
Parking brake bypass code on a Dual XDVD9101 head unit
there should be a wire that connects to your e-brake swith, located near the e-brake all you have to do is connect this wire straight to earth and you should be able watch movies all the time,
hope this helps you
Mar 13, 2009 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
Dual Parking Brake Code HELP!!
the esiest way to solve these problem is to make a switch connecting the blue/white with the brown cable it would work just find i had the same problem.
Mar 10, 2008 | Dual XDVD8181 Car Video Player
XO Vision XOD1742BT Car DVD Player Logo
957 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
