If it's a new modem/router, you need to have it approved by your ISP, Telkom. If it has worked before, power down the modem/router or both if they're separate devices. Wait a minute, restart. Usually there's a password available on a label on the router. Once it's on and working, you need to look for the router on your laptop/device. Connect and you should be prompted for the password.
SOURCE: BenQ P50 internet connection problem
For access the internet through wi-fi connection u need to do some setting on ur mobile .(like Access point etc). and if ur wifi hotspot is secured then u need to enter password or passkey while use internet Gizmo1
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: Connection to wifi internet
Try a new partnership with your pc and and use active syn to update your phone.
Under connections you'll find wi-fi in theresomewhere and choose it as default connection and you should be good to go.
Hope this els,
Steven John
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
