Question about Maytag MAH6700AWW Neptune Front-Load Washer
We are getting small holes in our clothes? Is
We are getting small holes in our clothes? Is this the washing machine?
  • 3 Answers
We had this problem with a new washing machine. Turned out the solution was to switch from a BIO washing powder to a NON-BIO!!
Didn't fix the existing holes though :-(
Posted on Aug 25, 2009
    Scholar:
  • 76 Answers
Check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
Posted on Aug 01, 2009
  • leanos325 Aug 01, 2009
    check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
  • 351 Answers
SOURCE: Smartdrive 703 Model Washing Machine Leaving
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Posted on Mar 14, 2008
Lumpy816
  • 246 Answers
SOURCE: neptune top load holes in clothes
You may have something between your basket (the area where you put your clothes) and your tub (the part that holds all the water in. Check all of the holes in your basket to see if you have something sticking/ protruding out of one of them. You might also have a hole that has been bent casuing a rough edge. Next pull back the edge of your boot (the gray ,rubber part in the front) Do you have any forighn objects in there? Finnaly for the washer, check the bottom of the door. A rough area on the bottom can cause the same problem. You might also want to check your dryer. Over time the seals (the gray rings in the front and back when you look in your dryer can be worn or have a forign object caught in them. Both will cause clothes to snag and tear.
Posted on Jun 15, 2008
  • 51 Answers
SOURCE: holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Posted on Mar 13, 2009
  • 10 Answers
SOURCE: Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Posted on Apr 18, 2009
  • 123 Answers
SOURCE: IS THERE ANYTHING I CAN DO TO PROTECT MY CLOTHES
hi there.....this Problem is usually caused by damage to the inner wash drum ( THE SILVER DRUM)...if you examine the interior closley you may find the damage and careful use of a rounded wood or lastic will allow you to reshae the small defects...alas it is usually a relacement drum that is the only safe soloution
regards Sir Galahad
Posted on Aug 13, 2009
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
My whirlpool washing machine has chipped around the holes in the tub and has rusted. It leave rust marks on my white clothes. Is there any way to repair the tub? The washer is about 5 years old but I am a...
You used to be able to get a brush on product that was used to fix chips in baths and appliances.. I can't remember what it was called, Check around some appliance shops perhaps they might remember?
Feb 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have w460 & i keep getting small holes in tee shirt type materials help!
most likley you have a rough surface in the drum, you may have had a underwire from a bra poking through one of the holes in the drum which has now distorted the hole allowing a sharp edge to protrude inward and damage the clothes. empty the machine use a torch if needed and rotare the drum looking at the surface for inperfections (dipmles in the reflection of the surface) once found use something wood or plastic to push the burr outward) away from the clothes I used to use a soft screw driver handle to move the burr away. if its not this then check the door gasket these can wear away and start to tear clothes but this usually looks more like a burn than a small hole.
Jul 20, 2009 | Miele Novotronic Premier 500 Front Load...
Holes in clothes
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Holes in clothes
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
After a washing cycle on wool wash, some items are not completely wet - machine is not overfilled. there is also fluff on some of the items
Look in the area where you place the clothes. in the back area about the 2o'clock posistion there is a small hole. usually this hole which recirculates the water becomes clogged with lint. If there is n othing there, you could have a pump failure,and it is not letting the water get back onto the clothes.
Feb 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Noise when spinning fast
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 15, 2008 | Hotpoint WMA44 Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Makes scratching noise
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
Mar 14, 2008 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
578 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
