Question about HP Officejet Pro L7780 All-In-One InkJet Printer
The device will not scan a paper document to my computer - the cord is connected and the driver is installed
    Problem Solver:
  • 5 Answers
First, power off your scanner, then shut down the computer. After reboot test the scanner again. If you still can't scan, verify that you have the correct driver for your scanner. To check for your current driver click start --> Control Panel --> Scanners and Cameras. Right click the icon associated with your scanner and select properties. You should be able to find driver info there. Verify this information at the manufacturers website as they will most likely have the updated drivers available for download. Also, for the best answers, in the future please include the make and model of your scanner and what operating system you are using.
Posted on Aug 01, 2009
I don't know how to get a scan from my HP7380 printer into my Acer Aspire5741G computer PLEASE TELL ME HOW TO DO IT
  • At first try to connect through USB
  • Just connect your printer data cable into the USB port of the Computer
  • On your printer
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your Printer.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your printer now installed with your PC.
Now if you want to scan a document then
Put a document into the scanner part of your Device and close the cover. After that Press On Scan Button.
Scanning will be automatically start.
Thanks
May 15, 2011 | Office Equipment & Supplies
How do I scan a document to my computer.
connect the copier to a computer with a cord and install the driver of the copier on the computer, then on the copier place the document on the scanner and press scan.
Feb 01, 2011 | Toshiba estudio 255 Copier
Cannot scan any documents to computer. Refer to
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
I can't scan a document into a Word file...
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Dell 962 Photo All-In-One InkJet Printer
Documents not printing
follow this steps 1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Nov 17, 2008 | Office Equipment & Supplies
Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    Aug 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    HP Officejet Pro L7780 All-In-One InkJet Printer Logo
    93 people viewed this question
    Seeker5211
    Seeker5211
