Question about Harman Kardon HK 3380 Receiver
The blue light on the HK 3380 Information Display is off. It doesn't come on even when I press Dimmer and then turn receiver on and off. Please help. Thanks very much.
  • moongate Aug 03, 2009
    Moongate has now solved Moongate's problem . . .
    • turned off the HK 3380
    • pressed and held front panel 'Mute Button' for five seconds
    • Information Display showed the word RESET and then returned to normal operation!
    That's it! Regards,
2 Suggested Answers
  • 308 Answers
SOURCE: my HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Posted on Mar 22, 2010
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
All display lights are illuminated but device doesnt work
Do you hear the speaker protection relay click after about 10 seconds when you turn the receiver on? Does the display show PROTECTION on the display? These conditions indicate a bad channel that will keep the receiver from functioning but you still have lights. Steve
Jan 14, 2014 | Harman Kardon HK 3380 Receiver
Instrument Panel Lights
Daytime headlight issue ? No , no sensor behind the front bumper . No Daytime time head lamp issue , doesn't turn on the instrument panel light's . This is more then likely a remote dimmer module problem .
Interior Lights Dimming Circuit Description (Pontiac)
When the park lights are on, battery positive voltage (B+) is applied via CKT 32 (YEL) to the remote dimmer module. The interior dimming switch in the lamp dimmer switch is a variable resistor which applies the dimming input via CKT 44 (DK GRN) to the remote dimmer module. The potentiometer in the lamp dimmer switch cannot provide enough current in order to operate the incandescent lights. The remote dimmer module amplifies the current, applying a variable voltage to the incandescent lights. As the amount of current increases, the lamps become brighter. As the amount of current decreases, the lamps become dimmer.
The radio, heater and A/C control assembly, instrument cluster, and passenger climate control each has a vacuum fluorescent (VF) display. When each module receives an input that the ignition switch is turned to the RUN position, each module activates the VF display at the full intensity. When the park lights are on, the radio receives the dimming level from an input on CKT 8 (GRY). The radio then relays this information to any other modules with VF displays. All modules with VF displays then adjust the dimming level of their VF display in order to match the level of the incandescent lamps.
May 16, 2017 | 1998 Pontiac Bonneville
How To connect Bose speakers to hk3380 receiver with my sharp hd tv
Step 1:
plug bose speakers in the little holes on the receiver
Step 2:
then turn up the volume and ur done
Feb 23, 2013 | Harman Kardon HK 3380 Receiver
HK 3380 Receiver - Power turns ON, then within a few seconds displays a PROTECT mode and immediately shuts off. I have checked speaker leads for shorting, etc. This unit was operating perfectly and then...
It seems that one (or both) of the power amps are defective. To have a quick check, take a meter, sett it on the DC voltage and measure the outputs, one by one (with no speaker attached and no signal) for the short time when the unit stays on. If you have high DC voltage on the outputs (one or both) this means that channel(s) needs repairs (most likely the power transistors are blown). If one of the paired transistors is gone you need to replace both of them anyway.
Good lock
Kostiko
Sep 21, 2011 | Harman Kardon HK 3380 Receiver
Where are the fuses in the harman kardon 3380 receiver, I had a lightning strike which I think knocked out my receiver thru my outdoor speakers, it will not turn on, could it be a fuse and if yes, where is...
Hello Randy,
There are two options here: first, the power button is amber but unit still won't go. In this case try a 'factory reset' as per manual. If this won't work, it seems that the processor is gone (located on the display board) so you have to bring your unit into a authorized shop for repairs. Secondly, it might be just matter of some blown fuses which are located inside the unit on the transformer board. If after replacing (if they're blown) the unit still won't work or keeps blowing the new fuses, follow the first advice, meaning you have to bring the receiver to a service. To access the fuses, you have to remove the top cover.I wish you luck
Kostiko
Sep 12, 2011 | Harman Kardon HK 3380 Receiver
Does the 3380 hk have an optical conecction?
No, it doesn't. But is a great stereo amplifier.
Kostiko
Aug 31, 2011 | Harman Kardon HK 3380 Receiver
My HK 3380 doesn`t turn on...
Mar 22, 2010 | Harman Kardon HK 3380 Receiver
Harman Kardon HK 3380 Receiver Logo
64 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
