Question about Polaroid PLA-4240 42 in. Plasma Television
I turn it on, everything can be read and functions but there are lines
Lines lines lines. Horizontal lines across the screen at even intrevals about ever 4 mm the entire screen. I just bought the tv today and this is what I've seen. I've never had an hdtv before but I'm thinking this isn't normal. I haven't looked at a channel yet, because I noticed this one the blue screen, no signal screen, and menu screen
  • CMinn Nov 27, 2007
    I slapped it one time on the side, not too hard, and it works fine now.
    I'm confused
  • Anonymous Mar 29, 2009
    audio at max doesn't get very loud -
  • 934 Answers
It's either the main or digital board - - - do not walk run back to where you bought it and get a refund... Then buy an upper end unit with one of the major brands... It will cost a bit more but you'll be MUCH happier...
Bill
Posted on Nov 25, 2007
  • William Rayburn
    William Rayburn Nov 28, 2007
    The there's a cable or connector loose in the unit and that can cause you some real problems... It may look good right now but it's a temporary relief..
    Bill
Limes across screen when first turned on, by turning off and on sometimes fixes it, what could cause that problem?
If the lines are colored or even look 3d it is a convergence problem--if other lines it will depend on what they look like and what the model number is.
May 27, 2012 | Mitsubishi Televison & Video
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Polaroid PLA-4240 42 in. Plasma Television Logo
190 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
