Question about Fedders AEQ07F2BG Air Conditioner
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
    President:
  • 704 Answers
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Posted on Aug 01, 2009
  • 398 Answers
Yes you want the outside to be lower then the inside so the water will run outside and not inside. just a slight amount will do1/8 of a inch will do.
What does the air exchanger do?
Pulls in some outside air as it runs to bring in fresh.
Sep 12, 2011 | Fedders AEQ07F2BG Air Conditioner
Fedders AC leaking water from front, older model was in storage. Cant find the manual to make sure it's installed proper, or see if we need to clean somehting out. It leaks when it's running, then...
The unit needs to be tilted down 1/4/" to 1/2" on the outside of the window. Also check the drain pan's drain hole, under the unit (outside the window) for clogs. Doing all of this should solve the problem.
Jul 11, 2011 | Fedders AEQ07FBG Air Conditioner
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
Is there a drainage tube or does it drain from the corners? on the fedders aeq07f2bg
Probably out the corners. The unit needs a big old puddle of water so the slinger blade can help cool the condenser coils. If the unit is tilted towards the inside of the hoscienda then water will come inside and will be spitting out of the evaporator. That ain't too cool (pardon the pun). You would need to reposition the unit so that the water will flow towards the rear of it.
That way the agua will disperce outside. Do not drill a hole or run a wire into the unit as that could bust the sealed unit. Not good.
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
On the fedders aeq07f2bg is there a drainage tube or does it drain from the corners ?
most newer a/c units have a weep hole or drain port on the bottom of the unit, some have a place where you can hoopup a drain line.
How do i install my fedders aeq07f2bg ?
in a window with outside tilted slighty down to drain
Fedders air conditioner 5200 btu manual ..i just need to know the angle that the unit needs to be on in the window
As rule of thumb the outside part should be lower than the inside part. You know that the angle is right when the water in the drain pan does not go toward the room but towards the drain itself.
I hope it helps.
Jun 26, 2009 | Heating & Cooling
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
Fedders AEQ07F2BG Air Conditioner Logo
61 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
