My PC doesn't goto the Safe mode and then not come to the TASK MANAGER and CONTROL PANEL
    Scholar:
  • 142 Answers
Check if you anti virus is up to date. When you try SAFE MODE does it restarts? If restarts and in normal mode havn,t task manager then try this go to here and unzip it then run process explorer in unzipped folder and find any unwanted soft running, also find process address and delete unwanted application. check startup in start meny>programs for unwanted apps. Update and scan computer with antivirus.
Posted on Aug 01, 2009
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Had a virus got rid off it but now screen is white and cannot do anything with it
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
I have HP vectra corporate pc and I have installed IE7. After installation I cannot get desktop screen (means start menu). IE7 creates Internet explorer error and for that reason I am unable to use my pc....
F8 is the key that you should push to enter safe mode, but you have to know the administrator password.
I can give you another hint.
When you enter Windows normaly, wait for IE error and after that try CTRL+Shift+Esc key combination. Task manager will pop-up. Choose File->New Task(Run) and type control or control appwiz.cpl. This should open Control Panel or Add/Remove programs and that way you can uninstall IE7.
Other option is to choose File->New Task(Run) and type %windir%\ie7\spuninst\spuninst.exe in Task Manager to directly try to uninstall IE7.
Good Luck!
Aug 19, 2011 | HP VECTRA VL PC Desktop
Black screen after windows start up. Power is on system boots up windows vista icon appears, and then the screen goes black.
Sorry you are having trouble. Try this: turn unit on. Press F8 to goto safe mode. Goto control panel. Goto System. Goto Device Manager. Look for display adapters. Remove whatever is listed there (write it down first) Reboot to normal mode. What should happen is that windows will detect a display adapter and install it. let me know if you need more info.
Apr 06, 2010 | Compaq Presario CQ60-220US PC Laptop
Switch on and get the Siemens logo then it blanks and the switch LED changes from green to yellow
ur boot vga resolution is too high try to press F8 rapidly,if menu came select safe mode goto device manager in control panel and remove ur vga driver and restart ur pc and try again
Mar 05, 2010 | Computers & Internet
While booting it stops at the background picture and will only let me use task manager in a limited scope.
Press F8 and start in safe mode. goto start/programs/accessories/system tools/system restore and restore to a date when your machine worked
Jan 23, 2010 | Dell Inspiron B120 Notebook
Some Virus has disable the aministrative rights form PC
I need some more information
Q1.do you get any kind of a messagewhen you try to open task manager?
Q2. do you get the same message when you try to open control panel?
Q3 Did you tried safe mode?
you can go to safe mode by pressing f8 on a restart.
please revert back so that i can give you the solution
Thanks & Regards
Tech 77
Jul 22, 2008 | Microsoft Windows XP Professional With...
Windows does not work
If you don't have any critical data on the computer, I would format and reinstall windows. That will help your computer run faster either way. Nothing runs better then a fresh copy of windows.
Good luck,
Lee
Jun 13, 2008 | Gateway 450 E (1121329) PC Notebook
While online my computer frequentlu , for no reason, goes offline.
How about go to windows Task manager and go to processes. Look for Kragg.exe. Dellete it. It is a virus that go infected the boot sector. Go first to F8 or safe mode. Then control alt dellete so you can go to task manager. If you are not sure of this kragg.exe virus, you may scan your computer with your antivirus while in safe mode. Maybe your antivirus will quarantine the kragg.exe virus.
Jun 12, 2008 | Computers & Internet
Anti vires uninstall
in the task manager go to process tab and right click on the process ie.antivirus program and click END PROCESS TREE...then try uninstallng the antivirus program...
by the way which antivirus program are u using???
the better one is mcafee
try to install this one.....
Feb 12, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
