Question about Toshiba Satellite A135-S2276 Notebook
Cooling fan stop working
I have toshiba A135 S 4527...from july 2007............some times its cooling fan stop functioning...........ultimately processor also freezes for some time...then it again start working..............i am in Haiti..where there is no TOSHIBA service centre...............i am waiting help from Toshiba community.............a friend from UNITED NATIONS HAITI
    Scholar:
  • 181 Answers
It's normal for the fan to stop and start, as needed. However, it sounds as if the heat sink attached to the processor and fan may be clogged with dust/fuzz/hair, etc. If you can, vacuum or blow air back through the ventilation ports to clear the debris.
This usually causes the fan to run constantly. It's possible that you need to adjust the power management settings in control panel-toshiba power management.
Also,try keeping the laptop in a cool place and see if it makes a difference.
Let me know how it works.
Good luck
Posted on Nov 27, 2007
MY SIMPLICITY MODEL SPAC6077 PORTABLE A/C HAS LOST ITS COOLING POWER, ANY TIP TO SOLVE THIS PROBLEM?
sorry to say but it might be time for a new one because when they sit for a long time and are not used the seals wear out and go bad . then the Freon leaks out so no more cold air only fan.
Jul 25, 2016 | Simplicity 6,000 BTU Portable Air...
The radiator fan on my 2007 bmw 525i works fine while car is driving. Once i stop at a red light or in traffic the the fan stops working, ac blows hot air and mins later the car overheats. The car has a...
My guess is that your electric fan is NOT operating at all. Under normal conditions, just going down the highway, your cooling system will function just fine without a fan running. The air flow through the radiator is adequate to keep things cool. However, when you stop, you quickly get into an "overheat" situation. Actually, you should be able to hear your fan begin operating when your engine temperature starts climbing or your air conditioner requires the fan to do its thing. Note: If you've ever severely overheated your engine, your problems may be worse than just a fan not running, but you really do need to confirm whether your fan is operating correctly, or not. Another note: I had a vehicle with a tendency to overheat when stopped. It turned out to be a faulty (leaking) pressure cap on the cooling system.
Nov 04, 2013 | BMW 525 Cars & Trucks
Two weeks ago on vacation car over heated a shop replaced the thermostat that was july 4 it is now july 13 and it is overheating again,PLEASE HELP!!!!!!! THIS IS A 2007 LINCOLN MKZ
My best advice is to ask a local mechanic to have a look for you as the cause could be a multitude of problems but i would suspect that the fact that when the thermostat stuck it has caused damage to the head gasket and you may even need the head skimmed as well so be prepared for a expensive job or trade this vehicle in quick
Jul 13, 2011 | Lincoln MKZ Cars & Trucks
Laptop stops wafter some working heating
I THINK you mean, Laptop stops working after heating up... If that is so, that means your Cooling system is not functioning, and the computer has turned itself off to protect your MOTHERBOARD, CPU, RAM and HDD from heat damage. Which means, you can likely get your cooling fan replaced in a shop for about 100 bucks (outside of warranty) and have your pc back the way it was when you got it new.
Aug 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
The cooling fan is not working
THe shutting down is your laptop's thermal protection. It is trying to keep the CPU from being destroyed.  You should stop using it until you fix it, or you will destroy it.
The fans are not hard to replace and toshiba disassembly is fairly straight forward. Just get your #1 and #2 phillips head screw drivers and pay attention to how you take it apart.
Call Toshiba and order replacement fans for your laptop as they will not set you back very much.
Feb 16, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Jan 14, 2008 | Toshiba (K000016310) Cooling Fan
Toshiba A135 S 4527 ......some times freezes
Virus information and help Below is a listing of some of the different properties a computer virus is ... Alter the system time / date. Cause system to hang or freeze randomly.
Computer questions and answers listing 700 - 800 CH000700, What should I do when a computer freezes?
Good Luck, Please dont for get to Vote, Thank You
Nov 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
187 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
