Question about Nokia e65 Cellular Phone
How can i have FM radio on my nokia e65?
Nokia e65
how to install FM Radio
    President:
  • 1,884 Answers
If Menu -> Media does not shoe any Internet Radio (you have to have GPRS connection for it) then go to Nokia site and download the Internet Radio. The best Radio. All Fm radios, about 2000 of them All languages, all countries, all types. Otherwise, there is no way you can listen to local FM stations.
Posted on Aug 01, 2009
Need an fm radio on nokia e65
That model of Nokia doesn't have an FM radio feature. There's no way to get one.
Here are the full specs of your phone:
http://www.gsmarena.com/nokia_e65-1860.php
Aug 22, 2011 | Nokia e65 Cellular Phone
I hav a nokia 2626.wen i insrt the air phn car kit sign is shown n i cant play the fm radio although i can talk using air phn so plz helm me out hw do i listn fm radio?????
if you use other brad hands free so your fm radio not work properly because your hands work as antenna also. its only possible when you use branded hands free.
May 07, 2011 | Nokia 2626 Mobile Phone
My nokia 5800 hangs while using fm radio
Oct 17, 2010 | Cell Phones
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
What is process for on fm radio without headphone?
IT IS NOT POSSIBLE TO ON FM radio w/o head set as an headset acts as the recieving antenna for the transmitted radio signals from the radio station
Jul 21, 2009 | Nokia 3110 Cellular Phone
Fm application for my mobile
hi,
connect the phone to your pc with nokia PC suite installed in your PC.
then go to install applications and then install your application
thanks you
Feb 08, 2009 | Nokia 7610
Nokia 5220 expressmusic FM radio always says off
I have the same problem and don't see a way to set the frequency of the stations if you can't set the radio to on...............
Nov 07, 2008 | Nokia 5220 XpressMusic Cellular Phone
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Nokia e65 Cellular Phone Logo
1,819 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
