Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Bios sees slave drive but XP will not accept it!
On an Asus A8S-X (soc 939) with latest bios I run XP (part C/D) with a slave as (part E/H) and everything runs just fine for @ 2 year. Then a crash, new drive installed same partition C/D. Up and running everything fine, but slave do not show up in XP. Drained it on another comp, re-formatted the drive. Started and yes bios found it. But XP did at first not to see it. After a few re-starts and checking for new hardware it did!! Made part E/H & format via XP, then reboot, but XP refuse to see it. Goes on an on. So changed to 2 new drive. Same problem. Again another 2 drives, same problem. (different brands). Now it's becoming a personal challenge of sort.
All drives IDE, yes tried all combination on the jumpers, changed cables etc. etc. I have been into this since 8088 20mg. (All drives runs fine as slave in other comp, dif. boards though)!!
Very seldom have I had problems with boards. Or could it simply be a problem in XP? In the meantime the XP on C/D drive, boots and work just fine.
Well, here's where it gets interesting. Installed Jauntry 9.04 as a master and mounted the 2nd drive as a slave. No problems there, Ubuntu loads both drives just fine?? This using drives that XP didn't see but bios did.
I'm very curious to find a solution, chucking a board without coming to grips with some form of closure is like giving up. And this was my last 939 soc board...
  • 2,418 Answers
Do you have the option to set the start time on the HD bios 1 second behind the MB bios? I think if you can find that option you will fix your problem. The Bios on your board will see the drive but during normal boot, Xp drivers take over to run the hard drive so if you can slow the HD bios to 1 second behind the board bios this will fix your problem.
Posted on Aug 01, 2009
    Sergeant:
  • 168 Answers
The first partition on the master is C. If there are no other physical drives, the next partition will be D.
However, introduce a slave drive and the primary partition on the slave becomes D, pushing the old D (the second partition on the first drive) to E. If you remove the second drive, E will once again become D.
If you are confused, think about the programmers that wrote that stuff. To further confuse things, Western Digital has a different setting for a solo drive and a master. The other manufacturers use solo and master as the same setting.
Through my rambling, you may have discovered your problem.
    Scholar:
  • 103 Answers
Did you formatted the drive using ubuntu? you need to have the primary partition at least FAT32 format or windows is no going to see it. You ca uses the other format Microsoft uses, NTFS, FAT16.
Can't boot from a usb flash drive using ASUS A8S-X motherboard.
Have you changed the boot menu in the bios to accommodate an external source?
Apr 18, 2010 | ASUS A8S-X Motherboard
Can I use a Amd athlon 64x2 dual core processor 4200+ 2.2 ghz on my A8V deluxe motherboard . socket 939
Yes, according to the Asus website specifications on the A8V Deluxe you are able to run the CPU. You just have to make sure that the CPU you buy is for Socket 939 and not AM2.
Please rate!
Cheers
Oct 04, 2009 | ASUS A8V Deluxe Motherboard
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
My computer starts windows and restarts
It would be best to start with a fresh bios flash that you can download from
http://www.perfectdrivers.com/drivers/Bios/Soltek-SL-K890Pro-939-Bios-T1-4
or
http://driverscollection.com/?H=SL-K890Pro-939&By=Soltek
After this is installed then start the computer in SAFE mode and run a full virus, malware and spyware scan.
Then restart the computer in normal mode and if it fails again you will have to use a Windows restore disc, if you have one, or use the Windows installation disk to start and run a Repair on the system then restart it. Then download all the remaining up top date drivers at
http://rapidshare.com/files/12368442/SL-K890Pro-939.rar (51.394 MB) No pass required.
And run a full virus, malware and spyware sweep on the download before using it. Then install all the latest drivers to you system and restart. Then check for any Microsoft updates.
Sep 29, 2009 | Soltek SL-K890Pro-939 Motherboard
A8N32-SLI Deluxe - Can not Load 'ASUS UPDATE' fro CD
It's not you. Asus's program from the CD doesn't function as you might except. You'll need to download, ASUS Update V7.06.02 Install Program for Windows 2000/XP/2003 & 64bit Windows XP/2003 within Bios Utilities. And flash your Bios from a floppy. Than download the Bios version you want. Having trouble getting the file to unzip? Download again but this time choose a different site. Like (Global) instead.
Luck!
please vote...
Feb 18, 2008 | AMD ASUS A8N32-SLI Deluxe Socket 939...
Windows xp
kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
Oct 21, 2007 | ASUS P5S800-VM Motherboard
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Boot Problem
Try using a spare memory. Is the cmos battery ok? Your bios chip may be defective. Are their any buldging caps on the mobo?
Sep 21, 2007 | ASUS A8S-X Motherboard
ASUS A*S-X not recognizing cpu
you should be able to press F2 or Del on boot up to get into the bios, but you should replace the battery first then set everything up as the cmos has obviously lost it's saved settings because the battery is flat.
Sep 10, 2007 | ASUS A8S-X Motherboard
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
136 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
