Question about Dell Dimension 5100 (D51L1) PC Desktop
CD STUCK CAN'T SEEM THE GET THE EJECT BUTTON TO WORK I PUT IN A AOL CD AND ITS NOT DOING ANYTHING NOR COME OUT. I HAVE A LAPTOP SLIDE SLOT.
  • Dell Master
  • 2,404 Answers
Take a paper clip and on the front of the drive there should be a small hole. Put the paper clip in the hole and push it in there and the door should come out and you can take the cd out.
Posted on Aug 03, 2009
  • 70 Answers
In front of CD ROM a whole put into any pin and push it try should come out....
Posted on Aug 01, 2009
    President:
  • 1,884 Answers
There is always a hole on the front of the drive. Put a pin thru it and press (not very hard) and the drive lock will unlock.
Cd player will not eject
A common failure of magazine-type CD changers is that a CD gets stuck in transit between the magazine and the player mechanism. It may be necessary to remove the unit and disassemlbe it to solve the problem.
Mar 06, 2014 | Land Rover Cars & Trucks
How do you remove stuck disk
If holding down the eject button on the keyboard when restarting doesn't work, then the easiest way is to insert a business card of credit card into the CD-Slot. Slide it in until it 'pops' the CD up slightly, whic release it. You can then use tweezers or similar to pull the CD gently from the laptop.
Nov 26, 2013 | Apple MacBook Pro Laptop Computer with...
How to get stuck cd out of ford edge
Steps to Remove a Stuck CD: 1. Take a blank/useless CD (such as AOL free trial CD's, you an get them in a plethora of amounts in Best Buy) and place it about 1 inch deep into the slot. 2.Press the 'Eject' button and gently wiggle the CD around.--------------------------------------------------------------------------------------
BMW M35080 Software version 3.0
Mar 05, 2013 | Cars & Trucks
I am needing to know how to fix mu 2004 chevy malibu cd player i cant get the cd to come out that is currently in it. when i try to eject the cd it makes a skipping noise and it wont come out. the cd...
This works for sure...
Things you'll need:
1. Old plastic card (an old credit card should do just fine I used a grocery discount card)
2. Timing
Start:
1. Hold the small side of the card like you're going to put it in a bank machine slot (not the sliding type)
2. Push the eject button
3. Immediately insert the card on the left side of the CD slot.. you may have to insert it rather far as it seems there's a switch in there. By my estimation, it feels like the card is ABOVE the disc.... try sliding in/out/left/right (sounds vulgar I know...but this works every time)
There is a point whereby if you don't get the CD to eject, it will display an error... watch your timing and how you move the card and try again....I swear this works.
Jun 05, 2010 | 2004 Chevrolet Malibu
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
How do I eject a disc from a Dell Studio laptop? It doesn't have a tray or door. You just slide the disc into the slot. I was adding Norton Antivirus software to the computer. It took the CD into the slot...
There should be an eject button next to the cd slot.there has to be,if its broken theres a small hole you can insert a paper clip and itll eject the cd.Buttton.But look for that button there small!!
Nov 02, 2009 | Dell Studio 15 Laptop
Dell Studio 15, CD stuck in slot
remove drive out there's 4 screws below drive remove them, you should be able to open drive in 2 bits remove cd put all back together ;)
you may have 1 or 2 more screws just remove them to open drive in 2.
www.e-repairs.co.uk
Jul 04, 2009 | Dell Studio 15 Laptop
Cd player
Some Tips and Tricks that you can try:
  1. Figure out what fuse controls the CD player and, with no key in the ignition, pull the fuse out for a minute (or more - I've seen TSBs that say leave the fuse out for 10 minutes), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio presets and other settings. Make sure you have any codes for your radio that may be required since disconnecting the battery cables can cause the radio to quit working too. This fuse trick seems to have the greatest chance of success overall. Check your owner's manual - you may have more than one fuse that controls the CD and/or the radio and you may need to remove all the related fuses. (There's a "risky" variation of this tip described in the Multiple (6-disk, etc.) Systems section of the guide for attempting to fix a CD changer)
  2. Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
  3. Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
  4. If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
  5. Some players, especially aftermarket ones, use a CD cartridge or magazine. Tapping on the cartridge while pressing the eject button sometimes ejects stuck discs. CarSpace member Alwaysfords2 has been able to remove stuck CD magazines by using a piece of shim stock or a hack saw blade and going alongside one of the long sides of the magazine to hit the release. You can rock the magazine a little bit in the slot to see the mechanism and it should be easy to release - sort of like using the little pin hole on a CD drive, the magazine pops up as soon as it is freed.
  6. Remove the faceplace from your player (be gentle; something like a butter knife often works without damaging the bezel or breaking tabs). Then look for a tiny, usually recessed little button that you can press. You may need that unbent paperclip to reach the button.
  7. Find a coaster in your junk drawer - by coaster, I mean an old CD that doesn't work. Or use a blank one if that's all you have. Insert the coaster about an inch into the slot (yes, on top of the stuck CD). Then turn the ignition on and hold the eject button and wiggle the CD around. Don't be hamfisted - you're just trying to give the player some traction to help it eject the stuck one. If this fails, then try slipping the edge of the coaster (or something even thinner) under the stuck CD and pry it up while pressing the eject button. Again, be gentle - you don't want to ruin the player when a pro may be able to remove the unit and free the disc for $20 or so.
  8. Find a Popsicle stick or something thin but rigid and tear off a few inches of Scotch Tape from that roll you keep in your junk drawer (next to all those ruined CDs you intend to make Christmas ornaments out of some day). Put the tape on the top of the stuck CD using the thin stick to help attach the tape firmly to the disk. Like the hint above, the idea is to lift the CD enough to enable the player to eject it.
  9. At least one CarSpace member had success releasing a stuck CD by, ahem, banging on top of the dashboard!
  10. Foreign objects stuck into the player, or CDs that miss the slot entirely yet wind up inside the unit usually require pulling the CD player to remove the disc.
  11. If all else fails and the repair is expensive, you may want to upgrade to an aftermarket unit.
Apr 27, 2009 | 2004 Chevrolet Silverado 2500HD
Mini cd stuck in my macbook
You can try this:
  1. Restart your Mac.
  2. After you hear the startup chime, press and hold your trackpad button.
  3. After a minute or so, and you think nothing is gonna happen, the disc ejects.
  4. Release the button once the disc ejects.
Mar 20, 2009 | Apple MacBook Pro Notebook
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
Dell Dimension 5100 (D51L1) PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
