Question about Dishwashers
It no longer gets the water hot, even when the Extra Heat button is pressed.
  • 123 Answers
Your dishwasher has a heating element and like all elements they can burn out. You can purchase a new one from the manufacturers website normally or Sears.com has a huge online warehouse of appliance parts.
Posted on Aug 01, 2009
My Balboa 300F hot tub will not heat up. I am not able to get it out of economy mode. What can I do?
First, balboa does not manufacture hot tubs! They make control systems for hot tubs. If you are no longer able to switch between modes, then your topside control panel buttons are dead or falling. But... Even if you are still in economy mode, spa should still heat up. Once a demand for heat is recognized, you have a "Heat Call" and heater should come on. Is the "heat on" light, illuminated? If so, water should be heating, if not heater element may be bad? A multi meter would be good here: is there proper voltage at terminals on circuit board to heater? If so, bad element! If no voltage, then heater is not necessarily bad, probably just fine, I would then look at sensors? Good luck
Feb 23, 2015 | Pool & Spa
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
My dishwasher is brand new and is not drying the dishes!!! they are still wet. the model number is she55mi 2uc/60
If you are using a quick cycle there is not a dry cycle included due to the short wash. Ensure you use rinse aid even if you are using a product that includes it, as this assists the drying cycle by breaking the surface tension of the water and allowing less water to 'stick' to the load. Check that you have the machine set to the use the rinse aid and that the intensive dry is on. This can be done by following the instructions in your manual.
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying time for improved drying.
This option is only for units with a display. If your unit has a display window, please follow the instructions below.
NOTE: The unit must be powered OFF before activating.
To activate:
Press and hold the left "Cancel Reset" button, then • press and hold the ON/OFF button.
The model number I think should read SHE55M12UC/60.
I hope this helps.
When the LED display window indicates a "0" or "1" • release both buttons.
To activate extra dry heat, press the left "Cancel Reset" • button until the display indicates "1".
To disable extra dry heat, press the left "Cancel Reset" • button until the display indicates "0".
Press the ON/OFF button to save the setting.
Jul 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
My heat takes too long to get hot.
check your coolant level and top off if needed. its probably time for a new thermostat as well. make sure you get one from land rover when you do this and the proper mix of coolant and distilled water depending on where you live. cheers.
Dec 22, 2009 | 2002 Land Rover Discovery Series II
My rowenta leaks hot water
It is probably calsified (boiler stone has formed inside the steam ducts). Clean the iron according to the instruction manual.
If you have no manual, do this:
Heat the iron to the maximum in upright position with reservoir full of water. Turn the iron to 'operating position' i.e. in normal ironing position horizontally over a sink or similar. Use the extra steam button to force steam thru the iron. When the iron cools down so that the steam is no longer strong and some water is clearly leaking out, place the iron into upright position again.
When the iron is fully hot again, repeat the steaming. Do this until you have no water left. Let the iron cool down, add water and repeat the procedure until the iron doesn't leak anymore.
You will see the boiler stone coming out like hard dandruff. You can pull out bigger pieces with tweezers or similar. But be careful since the iron is hot!
Hope this helps. I do this roughly every month or two to keep the iron from leaking on my shirts.
Nov 26, 2009 | Cars & Trucks
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
