Question about Fedders AEQ07F2BG Air Conditioner
Do i have to install fedders a/c at an angle to drain the water out?
  • Ned C Cook
    Ned C Cook May 11, 2010
    Give me an e-mail and I'll send you sdrawing
  • 154 Answers
Yes
Posted on Aug 01, 2009
I have a Fedders portable roll around unit that is leaking water all over floor from underneath the unit. it does not look like the drain line is clogged. used to drain through hose but does not anymore....
Hello, Take a clothes hanger wire in the hole a little ways and see if it is stopped up. If that doesn't work get a can of air and blow in the hole.
Jun 05, 2014 | Fedders Heating & Cooling
Fedders AC leaking water from front, older model was in storage. Cant find the manual to make sure it's installed proper, or see if we need to clean somehting out. It leaks when it's running, then...
The unit needs to be tilted down 1/4/" to 1/2" on the outside of the window. Also check the drain pan's drain hole, under the unit (outside the window) for clogs. Doing all of this should solve the problem.
Jul 11, 2011 | Fedders AEQ07FBG Air Conditioner
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
Need a window install kit. The original got
With a glass cutter, you could cut the glass to the correct size and using some angle aluminium strip and some silicone, then seal between the unit housing and glass. Hope this helps
Nov 04, 2009 | Fedders X Chassis A6X05F2B Air Conditioner
Do i have to install my fedders aeq07f2bg on an angle to let the water drain out
It is a good idea to have the rear just slightly lower than the front edge to prevent water (condensate) from dripping inside.
However, most window a/c's use the heat from the unit along with the fan to dispel the water out the back and/or sides of the a/c outside the house.
If you do have the a/c tilted just back a bit, it should prevent any surprises and puddles on the floor, if you leave the a/c running when you're not home, etc.
Hope this helps and best regards!
Aug 01, 2009 | Fedders AEQ07F2BG Air Conditioner
Fedders air conditioner 5200 btu manual ..i just need to know the angle that the unit needs to be on in the window
As rule of thumb the outside part should be lower than the inside part. You know that the angle is right when the water in the drain pan does not go toward the room but towards the drain itself.
I hope it helps.
Jun 26, 2009 | Heating & Cooling
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
Fedders AEQ07F2BG Air Conditioner Logo
41 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
