SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: t-mobile dash internet
you will have to enable the wifi option on your phone and then connect to a wifi hot spot or access point.your device does have built in wifi..please look for a swtich or something that needs to be used to enable wifi..usually you will see them on the system--connections as wilan or wifi..hope it helps!
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
SOURCE: before i used to be able to connect to the
check your internet option and make sureto delete cookies...save your provider,s gprs agin .switch off and restart your phone to use this service
SOURCE: I can't get on wi-fi because my Internet is
you must select the name of your wifi network and enter the wep or wpa( password). which ever you used to set up your router with.
