Question about Whirlpool Dryers
Gas dryer doe not rotate - Whirlpool Dryers
    President:
  • 704 Answers
It could be that the motor/drum belt has slipped off the pulley, or has broken.
You can unplug the dryer and pull it out from the wall and remove the rear access panel to see if you can see the belt and whether it has broke or slipped off the motor pulley.
If you need to get a replacement belt, you can get locally or online at several sources. If you want to attempt the repair yourself, you might want to look at how your dryer is put together. Go to searspartsdirect.com and enter in the full model number of your dryer and you'll see what it looks like and see a list of all available parts,
Just so you know, it will take some time to disassemble the dryer in order to get the belt installed and you'll likely need a hand getting the belt onto the drum once you get everything taken apart.
Hope this helps and best regards!
Posted on Aug 01, 2009
Fryer rotates but does not heat-dryer vent blowing clear
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 01, 2011 | Dryers
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Dryer turns on, drum rotates, clicks like it did to let gas start but does not ignite. Gas line is functioning. Does not get hot. LPG conversion kit used
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Estate TGDS840JQ Gas Dryer
Bosch WTL 5100 Tumble Drier rotates but does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Bosch Dryers
My Sears Elite Dryer does not heat but the drum does rotate.
heatman101
Oct 04, 2010 | Kenmore Dryers
My Kenmore Gas Dryer Model 110.97584120 does not get hot. The drum rotates. There is no problem with the buttons. Help, please. Thank you
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Kenmore 74602 Gas Dryer
My dryer still rotates but it does not blow hot air and it contineously rotates.the only way it will stop is if Iopen the door
heatman101
Aug 13, 2010 | Estate TEDX640JQ Electric Dryer
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Open Questions:
Dryers Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
