Question about Canon PIXMA MP600 all-In-One InkJet Printer
INstalled absolutely everything and re install... error code 6502
I installed the ink, then it would say yellow not in, or magenta not in... now they're all working 100% and i get the freakin 6502 code! Nothing in the manual
  • 4,041 Answers
Ok
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Posted on Jan 25, 2010
Error 6502
this error indicates a problem with an ink cartridge. this can include a bad cartridge, improperly installed, or possibly ink leaking out when installing it.
reinstall ink catridges.
Oct 17, 2013 | Canon PIXMA iP3600 Photo Printer
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
ERROR6502
Error 6502 is a ink tank position error, one of the contacts for the ink tank in the carriage could be bad, or simply a wrong cartridge installed. You can't use photo magenta in a magenta slot, or photo cyan in a cyan slot.
Jul 15, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Jun 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
May 31, 2008 | Canon MX700 Office All-In-One InkJet...
Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
527 people viewed this question
old marine
old marine
