Question about Zenith R57W46 57" Rear Projection Television
Zenith - IQD61W20 : powers on but no picture at all
  • 1 more comment
  • c_skinkle Aug 01, 2009
    the zenith IQD61W20 is a 61 inch rear projection television. not a laptop. it flashes red and then goes solid red at the front. no sound. and no picture.
    i have a zenith IQD61W20 61 inch crt television. It has three color guns. the unit powers on and the red light at the front of the flashes but no picture displays at all. regardless of what source i am on the screen doesnt light up at all. since this unit doesnt have a blub i am at a loss.
    it has not been moved recently and has not been hit by anything.
    Thanks. can you look at the two pictures i've attached? the first is the power supply from far away. the scond is close up on a gelly kind of blue thing that seems to be modled to the side of one of the capacitators. Does this this mean that capacitator is toast? is that supposed to be there?
  • Zenith Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
In your case you have a rear projection TV based on CRTs technology.
This uses three CRTs to generate the image.
Parts that can be fault are the following.
PSU.6871VPM068A , usually blown capacitor, the capacitors may be replaced by a technician for less.
CRT pwbs The CRTs are powered with a small high voltage board for each tube, the boards are sometimes called Ballast Board. Each board is about $80, but they must be ordered.
CRT tubes 900-10052 , Blown CRT may occurr, in case one of the CRTs must be replaced. The green CRT in the link is not in stock, it must be ordered.
Convergence board or ICs. A common fail is caused by one of the convergence ICs blowing. In that case a chip like the one below must be replaced.
The replacement is a delicate soldering job. If the resistors at the base of the convergence ICs are faulty, this must be replaced.
Parts can be ordered here, many parts will not be in stock, in that case it is necessary to call the seller.
Phone (800) 638-3328 or (800) 432-8542
Also parts here Phone 1-866-925-PART (7278)
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Let me know if you need further help, and please do not forget to leave feedback after.
Many thanks.
G.
Posted on Aug 01, 2009
  • Ginko
    Ginko Aug 01, 2009
    I cannot see very well, but that blue thing does not seem coming from the inside of the capacitor.
    When capacitor blow they get bulged and sometimes they leak, from here that looks like a rubber protection in front of the component.
    Be careful in there, capacitors can release big discharge even with power not connected.
  • Ginko
    Ginko Aug 12, 2009
    please let us know how it goes.
    If you have fixed your problem do not forget to leave feedback.
    Thanks.
    President:
  • 2,185 Answers
I've read the manual:
http://www.retrevo.com/support/Zenith-IQD61W20-TVs-manual/id/387ci570/ t/2/
Here is what it says about no picture or no sound:
• Is the AC power plugged in?
• Check that your AC power outlet works. (Test it by plugging in something
else or try another plug.)
• Make sure your brightness and audio controls are set properly.
• Try another channel. The problem may be with the broadcast.
Or for a more advance isolation:
It might be acapacitor or capacitors failed in the power supply board of your TV. Thesecapacitors can be visually located because they are usually vented orBULGING. The only way to verify this is by taking the back cover offyour TV.
I hope I was able to help.
  • 1,555 Answers
On powering up of the LT does it gives any beep sound. Does this problem started after any recent game playing or after any recent software installation. After starting your LT give it sufficient time to boot upto desktop level. When you assume it has come to that point press control plus alt plus delete. does that makes any difference.
Replacement cord for Zenith IQD61W20 TV
It can be bought from most of the electronic spare part selling shops. Select a good quality one, which suits to your device.
Jun 10, 2012 | Zenith IQD61W20 TV
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
Picture shrinking
This problem can be repair, its only the vertical sect..have defective capacitor or lose/cold solder. by resoldering the area sometimes will solve this.
Jun 09, 2009 | Zenith IQD61W20 TV
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Zenith IQD61w20/35 convergence problem
Goto www.TvRepairKits.com - they are experts in this model. There are a few key steps that have to be done during the repair - if not - it will not work.
Apr 19, 2009 | Zenith R57W46 57" Rear Projection...
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Zenith xbs245 surround sound system
xbs344 stuck on prgrogriv scan have sound but no picture
Dec 20, 2007 | Zenith XBS245 System
IQC50H94W Zenith Projection tv
check the flyback/hv-spliter sounds like it could be your problem also check horizontal ic
Jan 23, 2007 | Zenith IQC50H95W 50" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
