Question about Dell Computers & Internet
I have a Laptop, Dell Inspirion 9100. Recently it
I have a Laptop, Dell Inspirion 9100. Recently it has shut off automatically. After some testing, it seems to happen with the power cord. Either the AC cord is shorting or the Computer is shorting out. Once it shuts off, if you push the power button to start it again, the lights will come on, but the screen will not. Then the system lights go out again.
  • 736 Answers
The power cord often has a broken wire right at the little plug that connects to the computer ..that will cause your symptoms .. also will prevent charging of the battery .. when people wiggle that plug around a lot they sometimes break a solder connection inside the computer (dont do that) .. .. you can gently push the wire into the connector to see if you can reestablish the connections between the broken wire .. if you do you will be able to boot the computer .. thats of course a temporary test .. but if that works then you need a new power adapter .. or if you can find someone that can solder on a new tip to that power adapter then thats what i usually do .. they do have to know what they are doing though .. if they switch the wires they can damage the computer ..and you have to have the correct tip.
if you could charge your batttery in someone elses inspirion 9100, then you will likely find your computer working again until the battery runs down ..
Posted on Aug 01, 2009
    President:
  • 3,278 Answers
I would suggest testing your laptop with another adapter, first. Then you'll know whether to replace the adapter, which is priced around $50.
Find a windows 7 driver or a windows 7 replacement modem
Robert,
Unfortunately, Dell does not have Windows 7 drivers available for download for the Inspiron 9100. You can click the link below to download the online service manual for steps removing and replacing the modem in your computer.
Inspiron 9100 Manuals
http://dell.to/1KXJsjK
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2015 | Dell Bcm94154m Dell/inspiron 56k Mdc Modem...
Dell inspirion 1545 respond slow and shuts down even when on the desktop
The most probable, as far as I know, the hard drive is dying. Please test the laptop with a healthy (or brand new) hard drive.
Feb 18, 2014 | Dell Inspiron 6400 Notebook
The website will not let me respond to the fixes people have suggestedso far. My dell inspirion laptop will only run in safe mode. When itdoes start in normal mode it shuts down in 30-45 seconds. I have...
Could it be overheating, and automatically shutting-down, to avoid damage?
Shut it down.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job", shooting compressed air into every orifice, to remove all the dust that could be acting like a layer of "insulation", preventing your computer from cooling itself.
Jan 04, 2010 | Dell Inspiron B120 B130 1300 / Latitude...
Dell inspirion 1000 laptop computer will not allow me to work in safe mode keeps shutting down after booting up
It seems there is a heat related issue on your laptop. I would suggest to run first the diagnostic test, to check for hardware problem.
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Follow on screen instructions
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Re-installing windows will fix the problem. Hope this helps
Dec 30, 2009 | Dell Inspiron 1000 Notebook
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Vista
Try holding Fn + F8, that should give you video options or automatically switch you to the next video option.
Aug 30, 2009 | Dell Inspiron 6000 Notebook
Laptop won't pick up wireless signal
pls check first the antenna of your wireless lan be sure wireless card is properly inserted and driver is compatible too.
Jul 10, 2009 | Dell OptiPlex GX260 PC Desktop
No wireless network
I also have the Inspirion 9100. It is very finicky, try going thru the Setup wizard again and reset-up your wireless connection. If that doesn't do it...you might get a can of compressed air and use in the wireless card slot (if your using a wireless card), the bottom and on the keyboard. Surprisingly enough, I did the keyboard and the underside of the unit and it solved several minor lingering hardware problems.
Jan 14, 2009 | Dell Inspiron 9100 Notebook
Computers & Internet Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
