Sometimes it will come on for a few seconds before going off then blinks
SOURCE: The monitor goes blank after just a few seconds or sometimes works for hours.
My monitor worked one day - gone the next. Nothing on the screen except a bright green glow. No tech support for this problem. They want $70. just to look at it.
SOURCE: Playstation 3- described as the
Ok here is what I have for you
The Red light is due to the HDD (hard drive).
There is one of 2 problems:
1. The connection is loose or
2. The HDD is just bad.
This was an issue that has been discussed over in the Playstation forums and it seems that re-seating
(removing & reinstalling) the HDD has solved the problem for many but some people have just
received bad hard drives period.
If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace
your HDD.
The good news is you can pick up a hd fairly cheap, go to the electronics store and ask.. if you need step by step directions let me know I can help you out there as well!
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
SOURCE: As soon as you turn the system on, the power
hey
there rls When
your Experiencing Problems with the PS3 like this you mainly have 2
options to take, I will go through each one now so you know what to
do. Option
1 Send
The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will
send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will
be $150
Waiting Time:
4-6 weeks Option
The PS3 Repair guide
When your suffering problems with the PS3 its
often easy enough to fix it at home with a good ps3
repair guide. There famous for fixing major problems like:
The
YLOD - Yellow light of death
The
Hard disk Corruption error
The
Red Screen of death - Serious error
PS3
No Signal Error - no display
But not everyone knows they can fix simple
settings problems like all error messages and the no display error,
av and hdmi screen problems and more.
Price: averages between $30 - $40
Wait time: instant download and repair within 2
hours
I really hope I have enlightened you and you do
what is needed to fix your problems with the PS3 and get back to
gaming soon as possible
Please leave any comments if you need any
further assistance
Best Regards
Peter Fix
hey
there rls
When
do.
Option
Send
The PS3 to Sony
Price:
be $150
Waiting Time:
4-6 weeks
Option
The
The
The
PS3
hours
further assistance
Best Regards
Peter Fix
