Question about Continental CE-PAC1062 Air Conditioner
I have the CE PAC 1062 3 speed 9/10/11 BTU. I has
I have the CE PAC 1062 3 speed 9/10/11 BTU. I has a drain in the back and refers to a plug but no such plug came with the item. Where can I get a plug. It works like a charm. Thnaks oh please respond to snelson.patricia@gmail.com
2 Suggested Answers
  • 53 Answers
SOURCE: I have a Continental Portable airconditioning unit that I have to drain every couple of hours?
your problem is that u need a general cleaning ,an with out that u will still have that problem.Now if you have a little knowledge on how to open the system thats somthing u could do yourself..Once u get the system open locate the drain assembly ,make sure that pan an hose both are cleaned out an while you are there go ahead an clean the coils on the unit to prevent any head pressure an that the unit supplies air properly if you dont have any drain cleaner for your unit use ,bleach just a little cap full an pour in pan..an after you get it clean.once a year pour in drain hose ..That should take care of your problem
Posted on May 15, 2010
Delonghi PAC a120e ,why is it leaking and also is ther a filter
Don't know if this is the type issue you are having. I had my unit leak all over the place last year and found there was ice buildup on the inside of the unit. You would have to remove the cover completely in order to check this out. Also make sure the drain is clear.
Jun 16, 2014 | DeLonghi PAC A120E 12000 BTU Portable Air...
My PAC CN120E was working fine until the outlet that is above it started to smoke. I plugged it into another outlet and red lights came on but quickly disappeared. Can you advise if the unit is blown out,...
I cannot tell from which country or area of the world you are, but in the USA, your 12,000 btu a/c unit would take a special plug and electrical circuit in many homes or apartment, because it is so large.
Today, most circuits are protected with a 15 amp circuit breaker, which can usually handle only a 5,000. or 6,000 btu unit. The next size up it often a 7,500 unit, and that is a lot for a 15 amp circuit .Some older homes have a 20 amp circuit breaker, which can handle up to a 8,000 btu a/c.
Before you start a fire in your house, have an electrician check all this, and see what is going on.
One reason I am talking about such small a/c units it that usually, household electrical circuits have other loads on them besides the a/c.
Be blessed.
Oct 06, 2013 | DeLonghi PAC C120 12000 BTU Portable Air...
Tengo un aire portatil continental modelo CE PAC 10651 y se le partio el aspa que lleva en la parte de atras. donde puedo adquirir el repuesto por internet o hay un proveedor en Venezuela al cual pueda...
i no pudo localizar a ning?n proveedor parte de Venezuela. y, ┬┐puedo localizar una tienda que te pueda ayudar. si usted todav?a tiene el manual del usuario, buscar un n?mero de tel?fono de contacto, que puede llamar.
Aug 17, 2011 | Continental Dublin Series 13,000 BTU...
My PAC CT90-drain it how?
This system is set up to drain out of the back bottom all by itself, if it is not draining then simply tilt it back a little bit more so that the front is higher then the back and everything will drain just fine.
May 30, 2010 | Heating & Cooling
Aug 15, 2008 | Continental CE-PAC1062 Air Conditioner
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Continental CE-PAC1062 Air Conditioner Logo
Top Continental Heating & Cooling Experts
Tim Whalen
Donni Steen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
