Mitsubishi model VS-50603. pictures looks like very light shadows. audio is good.
    Novelist:
  • 133 Answers
Some possibilities are:
- incorrect screen / bias voltages
- a video / blanking circuitry fault
- a bad connection (may cause the above mentioned faults)
- a short in the picture tube may show as excessive picture brightness
- a burnt out or shorted resistance or a capacitor
Try tapping with a non conductive stick on the circuit board around various components (also the board attached to the picture tube neck), see if it affects the picture (if so, there's most probably a bad solder or connection contact.
For a more detailed description of this particular problem, please check the following site:
http://www.repairfaq.org/sam/tvfaq.htm#tvebaowop
There are descriptions for tons of different problems that occur on the TVs and the solutions to these, i would recommend this site to anyone who wants to learn about troubleshooting and TV repair. The main site is at:
Good luck and best regards
3rq8 (Triarcuate)
Posted on Aug 01, 2009
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
TV NO POWER
Good Day, HOGBOYLE;
I would highly suspect that the TV's signal board has CRT Coolant (fluid) on it. Check closely and remove/clean with acetone. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi VS-50603 50" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi vs-50603 no remote.what is code
Good Day, ariley1604;
Please contact comcast, and look into U- VERSE.
Aug 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
MITSU VS - 50603
Good Day, wecalvin;
Suspect fluid on the PCB's.To find suspected liquid on the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Aug 05, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
