Question about Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac
Just installed reason 4.0 and Ill make a nice pattern with one instrument, then when i import another instrument, it makes no sound when i press a key on my Bome's Virtual Keyboard..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 73 Answers
Sounds like you need to check the FAQ's on Reason's website.
Posted on Oct 10, 2009
1989 jeep 4.0 liter head torque bolt
they made over 5 million
and google searches seems to find them all. LOL
first hit. on google finds it,..
http://www.youtube.com/watch?v=X5HvYRcaL7c
best answer is see alldata.com and not build motors with rumors.
id never not fail to do that. (and win)
listen to Colin Hill, 27yr bolts are C-R-A-P, (called END of life)
they are not TTY and has nothing at all to do with this topic
ill not list why.!.. but can if asked.
my online fsm shows. updated proc.
even more important is order.
i sold my Comanche, they are rare and a great car. PU.
circular pattern from center outward, right side first.
1191 is new head, 53005535
  1. Install the cylinder head and bolts. The threads of bolt No. 11 must be coated with Loctite 592 sealant before installation. Tighten the bolts in 3 steps, using the correct sequence:
    1. Tighten all bolts to 22 ft. lbs. (30 Nm).
    2. Tighten all bolts to 45 ft. lbs. (61 Nm).
    3. Retighten all bolts to 45 ft. lbs. (61 Nm).
    4. Tighten bolts 1 through 10 in sequence to 110 ft. lbs. (150 Nm).
    5. Tighten bolt 11 to 100 ft. lbs. (136 Nm)
    6. Tighten bolts 12 through 14 to 110 ft. lbs. (150 Nm)
ill see if the old head is same. it is.
try alldata.com and stop guessing and digging up rumors
or post what are the top , 5 reason for new gasket failures.
1: not checked for warp, deck and head. then resurfaced.
2: using the old , bolts. dah?
3: wrong head gasket or not using a Felpro. using ebay china gaskets.
4: not using the steps in the FMS.
5:not getting head pressure checked.
Aug 08, 2014 | 1989 Jeep Comanche
Wrong cartridge error code on canon pixma mp780 printer
Reseating the print head is seldomly needed to be done.Press the Open Button (1) to open the Paper Output Tray (2) Raise the Scanning Unit until it stops. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.The Print Head Holder moves to the middle Open the Inner Cover 1.Open the Inner Cover 2.CAUTION: a. Do not try to manually move or stop the Print Head Holder.b. Do not touch any metal parts.Press the ink tank's tab (1), then remove it from the slot (2) IMPORTANT:Handle ink tanks carefully to avoid staining clothing or the surrounding area. Lift up the lock lever and take out the print head.Again, place the print head back in position and press down the lock lever. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot IMPORTANT:a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.b. If the ink tank is inserted in the wrong slot, perform two head refreshings.Close the Inner Cover 2.Close the Inner Cover 1.Pull the Scanning Unit Lever towards you to close the Scanning Unit.Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.Automatically Aligning The Print Head Position:Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].Press <Menu> epeatedly until [MAINTENANCE] appears.Press left or right arrow to select [AUTO HEAD ALIGN].Press <OK>. The print head position alignment pattern prints.Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete. Manually Aligning The Print Head Position:When automatic alignment does not work well, align the print head position manually.Load A4- or letter-size plain paper in the paper support or cassette.Select the paper source with <Feed Switch> button.Press <Menu> repeatedly until [MAINTENANCE] appears.Use left or right arrow to select [ALIGN PRINT HEAD].Press <OK>. A horizontal pattern is printed.Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.A): Column(0): Select pattern number with most solid image Press <OK>.Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].Press left arrow. A vertical pattern is printed.Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.Press <OK> Repeat steps 12 and 13 to adjust column N.
Oct 09, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Ok, i love the tones on this amp, but for some reason, i start to play, not even on at a high volume, just like at a nice level, ill play it for like 5-8 mins and it will shut off, like the power is still...
This is a tiny amp good for practice at low volume levels. You are likely overdriving it and the power amp chip goes into thermal protect. If you volume level is much louder than a small boom box, you are driving it too hard. Best to get a bigger amp.
Jan 26, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Hello. I am having a problem with Reason 5. The sound will not work- although I am getting a signal from the mixer, and it was working just fine a minute ago, there is no sound coming out of the...
I have the same problem, no word from Reason yet.
but what i keep doing is re-enter the program.
what i THINK the reason is, is that if you have soo many number of instrument programs hooked up to the mixer and what not, it blows reason 5's mynd!....
it has to be, because 3-4 yea your good, but 7 8 9 10, thats when i start getting problems! even fruity loops did a little better then this....(sad face). if i kno how to fix this foreal FOREAL, den ill post back..
Dre'
S.C
Jan 13, 2011 | Propellerhead Reason 5
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    How do I print the nozzle check pattern?
    Dear Sir,
    plz flow this step for solve your probelm
    These are the 2 important features for maintenance of your printer.
    Nozzle Check
    If your printouts are unexpectedly faint or have some missing dots or lines, it means that certain colour ink does not flow out nicely and consistantly. This is when you need to perform a nozzle check. If your nozzle pattern is good, then, your printouts will be good and nice as well. If your nozzle pattern breaks at certain parts, it means you need to clean the print head. Here's how to perform a nozzle check:
    1. Click Start
    2. Click Control Panel
    3. Click Printers and Faxes
    4. Right click your printer icon
    5. Click Printing Preference
    6. Click Maintenance
    7. Click Nozzle Check
    8. Click Print
    9. Click Finish (if the nozzle pattern is perfect) OR
    10.Click Clean (if the nozzle pattern breaks at certain places)
    The following is the sample of good nozzle pattern and a bad nozzle pattern:
    Good nozzle pattern:
    Bad nozzle pattern (Head Cleaning needed):
    Head Cleaning
    Head cleaning is required when the nozzle pattern is not perfect. Usually, this action is needed when you have printed a lot or you have taken out the cartridge for refilling or for other purposes. Here's how to perform a head cleaning:
    1. Click Start
    7. Click Head Cleaning
    8. Click Start
    9. Click Print Nozzle Patterns (to check the ink flow after cleaning)
    Thanks For Your Time,
    Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
    Auto head alignment
    #1 of 2
    Carryout a Manual Print Head Alignment If Possible.
    If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
    Head Alignment.
    1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
    Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
    2 Open the Paper Output Tray, and then open the Output Tray Extension.
    (1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
    (2) Open the Output Tray Extension.
    3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
    4 Select Settings on the HOME screen.
    5 Select Maintenance, then press the OK button.
    The Maintenance screen is displayed.
    6 Select Manual head align, then press the OK button.
    The confirmation screen is displayed.
    Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
    7 Select Yes, then press the OK button.
    8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
    9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
    (1) Select a column to input the pattern number.
    (2) Use the or button to input the number of the pattern.
    (3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
    Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    The 3eBK head stopped printing.
    Try below some steps which might help you resolve the problem.
    Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
    1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
    2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
      Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
    3. Press the <OK> button.
    4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
    If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
    Reseat Print Head Reseating the print head is seldomly needed to be done.
    1. Press the Open Button (1) to open the Paper Output Tray (2).
    2. Raise the Scanning Unit until it stops.
      1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
      2. The Print Head Holder moves to the middle.
    3. Open the Inner Cover 1.
    4. Open the Inner Cover 2.
      CAUTION:
    5. Press the ink tank's tab (1), then remove it from the slot (2).
      IMPORTANT:
    6. Lift up the lock lever and take out the print head.
    7. Again, place the print head back in position and press down the lock lever.
    8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
      IMPORTANT:
    9. Close the Inner Cover 2.
    10. Close the Inner Cover 1.
    11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
    12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
    1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
    2. Press <Menu> repeatedly until [MAINTENANCE] appears.
    3. Press left or right arrow to select [AUTO HEAD ALIGN].
    4. Press <OK>. The print head position alignment pattern prints.
    5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
    1. Load A4- or letter-size plain paper in the paper support or cassette.
    2. Select the paper source with <Feed Switch> button.
    3. Press <Menu> repeatedly until [MAINTENANCE] appears.
    4. Use left or right arrow to select [ALIGN PRINT HEAD].
    5. Press <OK>. A horizontal pattern is printed.
    6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
      (2): Good example (Most solid box)
    7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
      (A): Column
    8. Press <OK>.
    9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
    10. Press left arrow. A vertical pattern is printed.
    11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
    12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
    13. Press <OK>.
    14. Repeat steps 12 and 13 to adjust column N.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Wron catridge
    Try to reseat the print head:
      CAUTION:
      IMPORTANT:
      IMPORTANT:
      (A): Column
    8. Press <OK>.
    13. Press <OK>.
    Jan 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac  Logo
    123 people viewed this question
    Top Propellerhead Computers & Internet Experts
    Chris Larocque
    Nikki  Mclean
    Nikki Mclean
    solver2010
    Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
