By mistake I only inserted black drum unit in place of cyan drum unit while machine is on but I had not closed front door & not press start key. And before this I had made first time printing using network+ IP adress.
SOURCE: Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature.
turn off the unit.
Take the fuser out and reseat it.
Power it back up.
Ricoh Printers Error Codes
Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
SOURCE: Cyan Imaging Unit Failure, U28 Error Code
I just got that error couple of weeks ago on my 7300. I did everything you did and nothing so I ended up visiting www.iteminconline.com. I called them up and they told me to check all the cables on the engine control board 116-1538-00. I made sure the white data cables where connected and still nothing so they recommended me to buy a engine control board. That did the trick. Hopefully this will help you.
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
