Question about RIM Blackberry Curve 8300
No screen w/ red light blinking fast 4x's
I was told by the Verizon rep to take out the battery once a week, to let it "power down" and cycle. I noticed I was getting several message signals with NO messages having been received, so I decided to take the battery out to power cycle it. Upon putting the battery back IN, I now have a phone that will not turn on, and the upper right hand light just blinks 4 times very quickly.
I am presuming that I will need to take this BACK into the verizon store tomorrow....but, in the meantime, have NO phone, and my children are away at the coast....this is my sole way of communicating with them....and, of course, it's after hours for Verizon.
Any help out there?
  • Jae Robinson May 11, 2010
    I'm having the same problem... Finished a call (that dropped about 6 times) - Caller hung up - About 10 minutes later went to make a call - Screen was black - No keys working - red light blinking - indicating it was receiving data... Tried Soft reboot (Alt+Cntrl+Del) - no go... I could put the charger to the device and the screen would come "Up" - but the keys still did not work - and the screen would go black quickly... Take the charger off - same sequence... Took the battery out - discharged... Put the battery back in - Hour Glass comes up...after a bit the Verizon Logo...after more time...it jumps to the main screen...you can see it's trying to validate something - but the screen goes dark again - quickly... So what gives...?
I HAD THE SAME PROBLEM .
TOOK ME ALL DAY TO FIGURE IT OUT
JUST TAKE OUT YOUR SIM CARD PLUG THE PHONE TO COMPUTER OPEN UP THE LOADER AND IT WILL START.DID YOU SAVE ANY PROGRAMS TO YOUR COMPUTER.MJODY39@YAHOO IF YOU NEED HELP
Posted on Sep 19, 2009
Magnavox tv light blinks 1 then 4x fast.
Try to download the service manual to your Magnavox model, from internet. The TV shows fault code Here the fault code is "14"
First one blink is one=1
Second four blinks = 4
The service manual will have all the details about it.
Apr 14, 2012 | Televison & Video
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Verizon MiFi 2200 blinks red then shuts itself off when I plug it in. I know red blinking means critically low, but it won't charge and I have left it plugged in for hours. I held the reset button down for...
Mine did this, I went to Best Buy where I bought it. They didn't really seem to know, said it could be the power cord to the wall, but they didn't sell them. But they could set me up with an upgrade (and new 2 year contract that I didn't want). Anyway, I went to Radio Shack and showed them my MiFi 2200 and they had the new wall charger power cord there. Works now, problem solved for $25 instead of a new 2 year contract.
Jan 17, 2011 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Battery runs out in less than 60 min, used to go for hours.
Hi. With batteries it is very important to recharge them after each use, overnight. I have seen batteries last 7 years in a mobility scooter, because the batteries were charged properly. Batteries store electrical energy by means of a cemical reaction, and if left in a discharged condition for too long, damage is done to the internal plates of the battery.
Batteries are designed to do so many charge cycles.
If a battery is run down to 75% or more, you will not get many cycles out of it. If you only run it down by 25%, you will get 100's of charge cycles out of it.
I would say that you will need to purchase new batteries for it.
When changing the batteries, change one completely first, and then the other. This way you will be less likely to mix up the wires.
Red is positive, and black is negative.
Good luck. Neil.
May 30, 2010 | Quickie Wheelchairs Quickie Wheelchair 18"...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Blinking green
You may have the battery light reminder on...so you will need to take it off
Aug 30, 2008 | Verizon Communications BlackBerry Pearl...
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Shutdown; red LED blinks 4x
The most likely reason for the no picture might be the back light is gone and needs to be replaced, now as for the LED light blinking on different intervals is because its diagnosing it self unfortunately the user manual does not have any information on this part only by contacting the Phillips customer support you might get a better idea, but check your back light first it may just be that. Also try to check your Manufacturer warranty repair.
Sep 07, 2007 | Philips 50PFP5332D 50 in. Plasma...
RIM Blackberry Curve 8300 Logo
194 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
