Question about GE Refrigerators
Fridge always running
GE Eterna Series sidebyside fridge, hot between the doors. Fridge run constantly.
  • sjrotier Aug 01, 2009
    Thanks aasc!
    Looks like the fan is not working and the squirrel cage needs a good cleaning! Should have checked that when we bought it with the house 6 months ago... What should I do until I can get the fan motor replaced? I put a small fan behind the fridge to help cool it down. Anything else? should I shut it down until i can replace the fan? I don't want to ruin the compressor or make things worse. What should I have the fan blowing on? the compressor or the squirrelcage?
  • GE Master
  • 1,606 Answers
Check the fan which cools the compressor from behind the fridge . If not working , replace the fan motor . ALSO , check to be sure the coils under the fridge are clean of dust (from the front only ) .
Posted on Aug 01, 2009
  • Mike Smith
    Mike Smith Aug 01, 2009
    Squirl cage mainly , but compressor also if possible .
GE Profile Arctica PSS26MG freezer thawed fridge not cold sounds like running rubber on fridge door hot as where it closes between freezer & fridge
The door frame has a heater in it to stop condensation and the freezer door sticking shut with ice.
As both freezer and fridge have failed, you need to call a refrigeration engineer, as it either needs more refrigerant gas or a new thermostat, or (hopefully not), a new compressor.
Oct 23, 2015 | GE Refrigerators
I have an admiral refrigerator admiral designer series 21.1 cu ft.the motor is constanly running 8 to9 hrs at a time the left side of the door is always hot and the top of the refrigerator a repairman came...
yes compressor runs and shuts off every 8 - 10 hours for a half hour for defrost system mode. but ur hot left side may be a sign of issues needing to be addressed>
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 26, 2015 | Admiral Refrigerators
Hi I have a GE model# DSS25KGRE BB fridge. The fridge runs constantly, meaning it cools until the coils get all frosted up. then the defrost heater kicks on and 'thaws' the coils. I have tried
OK, first check the condenser coils and fan to be sure they are free of lint and dirt buildup. Dirty coils will keep the unit from cooling correctly and the unit will run endlessly. Post back the results to me and we will take it from there.
Regards,
Richard Roth
http://appliancecafe.com
Nov 30, 2012 | Refrigerators
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frenchdoor fridge keeps running constantly. Doors are fully closed and the temp seems right (now!!) but the motor keeps going. what can I check? Please & Thank you!
does it run all night too?
the fridge will run as long as it needs to to obtain and maintain the selected temperature,
the freezer should be set to zero and the fridge to 38
Sep 04, 2009 | GE PFS22SISSS Stainless Steel French Door...
Ge eterna series fridge side not working
Could you look inside the freezer compartment and after unplugged remove the panel to see if ice is blocking the vent to fresh food compartment. If there is ice it could be something is not working with the defrost cycle. Your refrigerator has a control board that handles these processes but other factors can cause ice buildup in vent. Thanks, Sea Breeze
Mar 26, 2009 | GE Refrigerators
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
drcool
Sep 07, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
409 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
