Question about Toshiba Satellite A135-S2276 Notebook
Fan stopped some time cooling fan stopped........meanwhile processor also stops working
  • Junko Guiass Nicolas Dec 01, 2007
    it turned of my toshiba A135-S227 and the next dey when i turned in on, only the power light and the orange light on the DVD ReWR come on. What should i do? The screen is not on, nothing els is on.
    only the power light on my labtop comes on, the computer does not come on.
  • 57 Answers
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Posted on Dec 14, 2007
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Dell Inspron 1000 processor fan stopped working. Is there an easy fix ???
The only easy fix would be to purchase a laptop tray that includes fans like those sold at OfficeMax and it would save you the trouble of having to open the laptop and maybe keep it cool enough to work for a while without it shutting down.
Aug 20, 2014 | Dell Inspiron 1000 Notebook
AMD Athlon 64 X2 Cooling System Failure: My computer suddenly turned OFF as if it was unplugged. i opened the cpu casing and cleaned the inside hoping it will solve the problem, but when i plugged the...
Sounds like you need a new cooling fan.You may be able to save yours with some electrical contact cleaner spray.
Remove fan and spray.
The cpu will heat up quick and shut down everything to protect itself.Im sure once you get a new fan you will be up and running again.
You may consider reapplying new conductive paste to the processor while you have the case open.
Aug 09, 2011 | AMD Athlon 64 X2, 2 GHz 4600+...
My dell dimension 8250 'Sound Blaster Live' will work for a few minutes, then shuts off. If I wait, it comes back again, etc. What's wrong? Thanks.
Thats your system restarting every small minute then the problem lies on your processor or probably your processor fan that is blowing air to your processor stops working and that can cause it not be ok after a short time it will be over heated and have to cut off and restart again what you will have to do is to change the processor fan or probably add a cooling paste on the processor cooling sink or if that persist change the processor.
Mar 06, 2010 | Dell Dimension 8250 PC Desktop
My dell inspiron 1525 suddenly shutdown after working for some time. i think its processor fan stops ...
Request you to write the problem clearly.
are you able to restart the system now?
did you check the battery charge?
Jan 13, 2010 | Dell Inspiron 1525 Laptop
Warning on boot up cooling fan on power supply failure
You have some fan with termal swich, they work only when you comp have high temp. Look that fan when you play the games, they must work some time and stop.
May 15, 2009 | Dell Precision 530 XEON Workstation Dual...
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Cooling fan stop working
It's normal for the fan to stop and start, as needed. However, it sounds as if the heat sink attached to the processor and fan may be clogged with dust/fuzz/hair, etc. If you can, vacuum or blow air back through the ventilation ports to clear the debris.
This usually causes the fan to run constantly. It's possible that you need to adjust the power management settings in control panel-toshiba power management.
Also,try keeping the laptop in a cool place and see if it makes a difference.
Let me know how it works.
Good luck
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
CPU fan failure
The bearings in the fan or internal mechanism may have burned out. If the fan does not generate a cool enough environment, you run the risk of frying the processor and other motherboard components that are temperture sensitive.
Replace, don't attempt to repair.
Keep me posted.
Oct 27, 2007 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
240 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
