Question about RaidMax Scorpio Mid-Tower (Blue) (16116)
Raidmax Scorpio 868
Blue power led on a Raidmax Scorpio computer case will not light up. All connections seem right as it have worked before. I disconnected and reconnected it a few times as I was installed a couple fans.
  • 119 Answers
Re: Raidmax Scorpio 868 - RaidMax Scorpio Mid-Tower (Blue) (16116) Computer Cases
Yes they are.try to change it
Posted on Feb 03, 2008
0 characters
3 Points
case sounds fine, a little iffy on the power supply.
Feb 20, 2010 | Computer Cases
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Power LED
Remove the hdd connector from the Mb. Borrow or buy a hand help AC. DC OHMS meater.
Run a OHMS test across the two pins. If OHMS reads zero the bulb is bad.
Nov 26, 2007 | RaidMax Scorpio Mid-Tower (Blue) (16116)
Fan not lightning up
there should be 3/4 small led (light emitting diodes) on the inner of the fan check the integrity of the solder on the wire to this led strip if there are any breaks in this then it can be re soldered.
if the fan is part of the PSU (power supply uinit then consult your local pc repair shop do not open the PSU.
If its just a case fan it would prob be easyer just to replace the fan.
hope this helps
Nov 03, 2007 | RaidMax NINJA 918 ATX Case
Doesn't power up anymore
use a test pen and check if any power coming out from the power supply cable e.g. to hard drive, motherboard and so on.. this will help to to find out if it is actually power supply issue or components issue....
Aug 29, 2007 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Red Light instead of a Blue one
I've seen this before. The power LED needs to be replaced. If you have the sales receipt, Raidmax will replace it. This won't affect any other part of your PC, so if you don't get it replaced, it's not the end of the world. =)
Jun 08, 2007 | RaidMax NINJA 918 ATX Case
Scorpio 868W
the connectors will be labelled as all cases are, but the manual for your motherboard can be downloaded from here:-
May 27, 2007 | RaidMax Scorpio 668WB (DSRMA668WBK)
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
RaidMax Scorpio Mid-Tower (Blue) (16116) Logo
178 people viewed this question
Top RaidMax Computer Cases Experts
Brian Sullivan
Brian Sullivan
soumen dutta
soumen dutta
Are you a RaidMax Computer Case Expert? Answer questions, earn points and help others
