Question about Craftsman 25cc Gas Line Trimmer
Craftsman 32 cc
The one fuel goes from the tank to the primer ball then to the carburator. question is there a T connection for this to work
  • 162 Answers
Theoretically the primer ball is the t connector.
Posted on Aug 01, 2009
How do you install gas lines on a 32 cc Craftsman weed whacker - which line goes where
The Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Oct 22, 2010 | Garden
I'd like to have a little diagram of the correct possition of the gas hoses coming from the gas tank to the primer and carburator for a Sears Craftsman 26 cc blower 150mph 340cfm
unfortunatly there arent any diagrams, my best advise would be to install the fuel lines leaving excess to trim off as you route them betwixt and between. remember that the fuel lines complete a circuit and that the primer bulb does not pressure up the carb, all it does is circulate fuel through the system and makes a loop
hope this helps and good luck
Nov 20, 2009 | Craftsman Garden
How to but back the gas line from a craftsman
There are 3 separate lines. Usually one is a bit smaller than the others. One line goes from the primer bulb to the tank..Usually the small one. Another goes from the tank to the carb...usually an inline filter in this line. There are 2 connections on the carburator...connect to the lower one, if you have 2 different sizes of tubing, this will be the larger of the 2. The 3rd line goes from the primer bulb to the upper carb connection...this is also a small line (if your model has 2 sizes of tubing). Good luck.
Oct 23, 2009 | Garden
Routing of fuel lines
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Oct 01, 2009 | Craftsman Convertible 14" Gas Line Trimmer
The fuel lines were brittle. I need to know how they hook up to 33 cc
The typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need to replace the gasoline pickup tube on a Homelite SX135.
The typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 02, 2009 | Craftsman 25cc Gas Line Trimmer
Nedd to put back the gas line
This is the typical fuel line routing on many models: One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
32 cc Craftsman (Poulan) gas line replacement
Yes, you are right. The larger line goes to the primer bulb and only goes into the tank about an inch. The coupling just keeps the line from pulling out of the tank. The smaller line goes to the carb. This line must rest comfortably on the bottom of the tank with the filter attached to the end.
Jim
Jun 07, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
223 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
