I think I held down a button or pressed something Can you help
SOURCE: ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
SOURCE: nokia 6110 navigator rear camera not working
I have the same problem and i know what it is. There is a little tiny switch and it turns on Camera when u slide cover down and it is broken. You should take your phone to repair or buy spare part https://www.oemcellphoneparts.com/products/Nokia-6110-LB-Flex-Assembly.html and fix it yourself.
SOURCE: 2004 Ford Expedition rear floor cool/heat
Item
Part Number
Description
Air inlet door
Temperature blend door
Headliner airflow
Auxiliary mode door
5
Floor airflow
6
18476
Heater core
7
19860
Evaporator core
8
19805
Blower motor
The auxiliary A/C and heating system has the following features:
I would say the auxiliary mode door (#4) electric motor is not wokring.
Auxiliary Blend Door Actuator —Air Distribution
Removal and Installation
SOURCE: Media control buttons doesn't work???
Actually many laptops & their media are designed only for working with XP or previous versions. So its not neccessary that they work good with Vista also. Its true that they should be compatible with Vista but not very necessary. So you may need to change your OS again to access all functionality.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
SOURCE: my laptop thinks the control button is held down
u r keyboard is likely to b defective or ur ram..
lightly strike/tap the keypad using ur hand..
if
u r a professional, open the keyboard..deep clean all the carbon
contacts beneath the keys using Iso-Propyl alcohol..put/stick
'Carbon-Dots' (available in cheap level spare market) as n where
necessary..
hope it'll work..
better to seek professional supervision esp of ur system admin/vendor....
