Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Netgear wireless router wgr614 not transmitting
Netgear wireless router wgr614v6 not transmitting signal to laptop anymore or cellphone...I can no longer transmit a steady signal...It keeps dropping out. Will changing the channel from 11 to 1 make a difference?
  • 442 Answers
Yes changing channel will make a diffeence most of the time for this kind of issue. The reason is there could be multiple routers or interference in that area locking to the same frequency.
Posted on Aug 01, 2009
Netgear WGR614 Wireless Router what do i need to
Theoretical covrage is 600 feet ... 300 on each side of the antenna ... provided there are no walls, no trees, no cars etc. between you and the antenna. If you want to go further, you will have to get a 'bridge' and commercial grade repeaters/antennas which may transmit as far as 1000 feet or you may want to get high power equipment that will transmit further ...
How big are your 'blocks'? Trees? Buildings? EMI in the area?
Jun 26, 2010 | NetGear WGR614 Wireless Router
What is the latest netgear firmware for wgr614v6
The latest firmware for WGR614v6 is Version 2.0.19_1.0.19
May 20, 2010 | NetGear WGR614 Wireless Router
Sorry if this seems a repeat question but I can not find the answer on here... I have a Netgear 54 Mbps wireless router WGR614v6. When I plugged it in, it does not have a wireless signal. Please note that...
for the laptop to detect the router you need to install the router's driver in you laptop and follow the instructions while installing since its a new laptop it always need to be configured.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
It simply stopped transmitting a wireless signal--it is still receiving the signal from my cable modem. I have a Netgear WGR614 v6
The router no longer works at all--I have to buy a new one if I wish to continue using my current ISP, which I do not. I am changing to Clear service which is wireless and they provide the necessary equipment. Thanks
Dec 22, 2009 | NetGear WGR614 Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
New computer lost install disk!
Hello, Here is a link for the firmware and drivers for your router. Hope this helps.
http://kbserver.netgear.com/products/wgr614v6.asp
Mar 23, 2008 | NetGear WGR614 Router
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
WGR614v6 - Bridge mode
This may provide some input for your request.
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=23547&action_code=5&highlight_info=16777285,88,115&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=18710634#__highlight
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
391 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
