Question about SanDisk Sansa c200 MP3 Player
Battery trouble how do charge the battery and how do know when its full?
  • 1 more comment
  • Anonymous Apr 20, 2008
    how do you charge it
  • Anonymous May 10, 2008
    how do i charge the battery
  • smiiley Oct 10, 2008
    ...But how do yhu charge it overallllll??
I do not have a solution I was looking for one!!!!!!!!!!!!! I have had 4 sansa c240 and they all quit working on the batteries and this one is slowing down too!!
Posted on Oct 19, 2008
    Problem Solver:
  • 3 Answers
Just stop charging it and unplug it, then check on the top right of the screen to seen if it is fully charged.
Posted on Jan 15, 2008
Charging problem with 2007 Buick Lucerne
I don't know what testing you have done? This is part of your generator wiring diagram. Make sure battery has a full charge and battery connections are all good. Use a test lite or digital multimeter at bat terminal, engine off, should be battery voltage, if not maybe the fusible link or wiring circuit has a problem? Check the rvc fuse. Your charging system is computer controlled, any applicable trouble codes? I can't rule out problem with generator, it self?
Feb 07, 2018 | Cars & Trucks
I have had my 55hp 1969 evinrude running good in my yard and 3 times then took it to the lake and it will not start. After trying 3 or 4 times it acts like the batteries are about drained.
Are you sure your batteries are up to snuff. Some batteries will tell the charger they are charged up but in fact they are maybe half way up. Before spending a lot of money on repairs get your batteries checked out at a battery shop. There should be no charge for that. If they are a couple of years old or more that could be the trouble especially if they are not kept charged all the time. If a battery is not kept charged full after a while it will not keep a full charge .
Aug 02, 2017 | Boating
Battery light stays on
Check your charging system and battery wiring circuits. Any applicable charging system trouble codes?
Make sure battery has a full charge, can't do much testing if battery is down.
What is year--make--model? If your vehicle isn't sold in the US, doubt if my database will have any wiring info for it.
Sep 19, 2016 | Cars & Trucks
I left a 1960 sears battery charger plugged into my boat battery, how long before it ruins the battery, when I forgot the battery was plugged in, it was fully charged.
Hey Mike, I can't find a Sears model #1960 charger, so I don't know the specs on it. If it is a typical old school 2 / 6 amp charger or any other that does not automatically shut off or switch to trickle charging, you may be in trouble in a day or two or longer - depending on the charge rate you picked and the percentage of full charge battery was before you connected it.
Dec 07, 2015 | Cell Phones
The car off the headlight stay on r comes back on later i changed out the headl switch in side the car and still have the problem and it drains the battery.
I'd make sure the battery has a full charge? Don't let the alternator charge it, if down very much, use a battery charger. Also, check your charging system.
Is your headlamp system full auto, meaning you can't manually turn off your headlamps? If battery is down, I don't like that system at all. You don't want to run around town in broad daylight with the headlamps on and the battery down with the alternator trying to do everything.
If full charge on battery and charging system ok, check for applicable trouble codes for bcm and or headlamp codes. Some of the national brand auto stores will check codes for free. In the diagram, the left side of module and hi beam relay, is the control side, has to have voltage and ground. The bcm supplies ground for one and voltage for the other. The bcm knows what's going on because of headlamp switch. I know you said the switch was new, but, what about the switch wiring to or from the bcm.
May 17, 2015 | 2005 Buick LaCrosse
Why my power windows,dome lights,dont work plus car wont start
ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
Sep 09, 2014 | 2004 Ford Explorer XLT
YN 565EX wont firing
I don't think this looks like any camera. But I know you can use this on a digital camera.
If the 565EX stops after 11 flashes, it could be it is warm. It could be the overheat sensor is a little bit to quick to respond. There also could be a problem with your batteries. If they run low in a short time, they cant deliver enough power to charge the Flash.
Try new batteries and be sure you charge them correct. Using an old charger with new (high capacity) rechargable batteries, is asking for trouble, because the old chargers can't charge modern batteries to full capacity.
Nov 06, 2013 | YONGNUO Cameras
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
Sep 16, 2012 | Razor E200/300 Electric Scooter Battery
How I know my lg lsp 350t has full charged
When your lg lsp 350t is fully charged, it stops reading like it is charging. You can also turn off the phone and plug in the charger, once it is full, the battery meter will turn blue or show battery full. \but when the phone is on, the way you will know that it is fully charged is that the battery shows a full bar and does not charge anymore.
Hope this information helped.
Jan 14, 2011 | Cell Phones
Showing not charging display on screen when we hold for charging the mobile.
becoz dear you have wrong battery in your cell phone
get the right battery from shop and then try
if you not able to done this mated try some other ways
get universal charger and charge your battery from its
and when battery full then putt battery in yor cell phone
the battery is full
Jun 13, 2008 | Nokia 3330 Cellular Phone
SanDisk Sansa c200 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
