Garden Logo
Darrin Jarrells Posted on Apr 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas is getting into oil in my John Deere riding mower la 135
Pcm2048
Level 3:
  • Master 754 Answers
  • Posted on Apr 19, 2018
Pcm2048
Master
Level 3:
Answers
754
Questions
0
Helped
200950
Points
2186
It sounds like you have a serious engine problem and I suggest you stop trying to run it as you may cause a lot more damage. Take it to a John Deere repairer who will be able to find out what is wrong with it.
5 Related Answers
Anonymous
  • 302 Answers
  • Posted on Aug 27, 2009
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Testimonial: "Thanks. It worked!"
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 02, 2009
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Anonymous
  • 742 Answers
  • Posted on Apr 19, 2010
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Anonymous
  • Posted on May 01, 2010
SOURCE: chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Anonymous
  • 146 Answers
  • Posted on Jul 04, 2010
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Gas is leaking into my oil causing it to smoke and eventually stop, john deere la 135 series
it needs a new needle and seat in the carburetor. just buy a kit. it will have everything needed to rebuild the carburetor.
Where can I find a belt for my mower LA 175 John Deere mower
Your local John Deerer dealer or online at a place like
John Deere Parts Online Discount Store Green Farm Parts
Drive belt GX20006
Deck Belt GX31395
1helpful
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
John deere la 105 is not getting gas to carburetor. changed pump and blew out lines
Take line off fuel filter and see if you fuel. Check the outlet in the tank and fuel cap vent.
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
La 135 won't start
If it was black smoke, then you're getting too much fuel in the system, which could be a lot of different things...air intake restriction, float in the carb, choke cable, etc.
12helpful
Chute for bagger keeps getting clogged
Apr 22, 2009 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
