Question about Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 laptop battery isn't charging, I think :(
I have a Dell laptop (inspiron 6400), I also have changed my battery with a new one (Type KD476 - Capacity 85Wh) but I don't think its charging. On the right side, the charge button blinks on & off, slowly .
I plugged this new battery in about 6 hrs ago, but the laptop still does not power on. Any suggestions? Would be greatly appreciated!
Thanks,
Debby
  • 1 more comment
  • blueeyesjust Aug 01, 2009
    Thanks for replying back....
    OMG! I didn't know a laptop would work without a battery as long as it was plugged in!
    1st its my daughters laptop. I noticed before the laptop died, it said something about a battery needing replacement. Then she told me her computer won't turn on. So after many months, I just ordered the new battery, plugged it in today, and several hrs later, tried to power it back on, 3 lights lite up then nothing. I don't know what is wrong with it.... Any suggestions? Debby
  • blueeyesjust Aug 02, 2009
    I guess it wasn't the battery afterall, I tried to power on without the battery, it wouldn't do anything but the 3 lights do light up for a minute, but nothing happens. The AC adapter when plugged in, has the green light lit, so I assume that it is working.
    Thanks,
    Debby
    I also changed the Cmos battery and still nothing. I hooked up a monitor to it, nothing. Besides the 3 lights, it appears like the laptop is dead! I don't understand why it would just die after exactly 2 yrs.
  • hmlee390 May 11, 2010
    hmmmm debby the laptop should power on even with or without the battery if the charger is plugged in ..if that is happening ok and you are just having trouble with battery operation .. then this might shed some light .. Lithium batteries have a couple of quirks .. when the computer indicates that the battery is dead they are far from being dead .. its just that you cant allow them to go lower than a certain voltage .. if the battery has been stored for a long time then it might indeed go lower than a critical voltage .. if you try to charge a very dead lithium battery then it could cause overheating or even an explosion .. to prevent that the modern changer will refuse to charge a battery that is lower than a critical value .. the charge light should flash in a special way to say something is wrong .. sometimes if you know a lot obout these batteries then you can jump start them .. just to get a little charge to overcome the critical voltage threshold .. there are even special chargers that do that but its not safe unless you are knowlegable .. .. so its possible that your new battery just spent too much time in stock before you received it .. or you might have problems other than the battery .. if your old battery did the same thing then i would worry about your charger or computer having a problem .. i guess we need a bit more information : 1. does the computer work on the charger alone (without any battery) 2. does it work with your old battery at all ..or do you get the same results as the new one .. 3. do you get the same flashing light with your old battery pluged in .. since the light keeps flashing i am assuming that the cord from the charger is ok . those break a lot right at the connector that plugs into the computer .. if that happened the light would not keep flashing .. if you know anyone with that computer you could change batteries to see if that works .. also power supplies ..(maybe at a local store that carries those) .. i happen to have the same model .. nice computer .. runs cool but its video card (intel 915 chip set) doesnt like the new "Windows 7" ... hopefully microsoft will fix that before the release date....
    Sergeant:
  • 168 Answers
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Posted on Aug 01, 2009
    Problem Solver:
  • 5 Answers
Hi..Check this link to get the solution for your queries:http://www.dellservicecenterinchennai.in/dell-service-center-locations
Posted on Nov 22, 2012
I bought a non dell battery for my inspiron 6400 note book but it wont charge,looking for a solutions,dell batteries too expensive john dublin ireland
the laptop will work with just adaptor plugged in and the battery removed.Try only adaptor plugged in.
Hoping this will work
thanks
Jan 05, 2011 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 buttery does not charge with Windows 7 !!!
Try looking it up in the power options menu in the control panel. There must be some battery settings you can check.
Aug 20, 2009 | Dell Inspiron 6400 Notebook
My laptop battery does not charge.
motherboard of laptop get faulty
repair the charging circuit of motherboard
Jul 28, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 - Battery replacement
Depends on your use. The 9 cell will hold a charge for about 2 hours, depending on your configuration and the 12 I believe is 3-4.
Feb 21, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6400 Battery problem
what i would suggest is to check the bios there may be a new flash download on the dell website, my wife has a inspiron 1525, which is plugged in and says not charging, the battery will not go above 0%, but we have had to send it to dell (still under warranty) faulty motherboard. if the bios is up to date, there could be a hardware issue with the battery or motherboard
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
745 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
