Question about NetGear WGT624 Router
I don't know my password in order to sign on to my IPhone wi-fi. Can you help
  • 1,272 Answers
To check the password follow the steps below on a wired computer connected to the router. 1. Open browser and type the address as http://192.168.1.1 or http://www.routerlogin.com. 2. Login with username as admin and password as password. 3. Click on wireless settings in the left hand side menu. 4. Under security options if wep is selected then check the code entered in key1. If WPA is selected then the password is in the passphrase. This is the password for wireless connection. Rate it, if it helps.
Posted on Aug 01, 2009
I need help to set up my Iphone with Wi-Fi access. Where and how to find my password for Netopia router?
Netopia routers use as default the following passwords:
1234
admin
password
Sep 20, 2014 | Computers & Internet
How to activate wifi of myphone tw8?
In order to work (both when registering and dialing), your iPhone will need to make a data connection to the RingFree servers. Wi-Fi, though not always available, of course, is your best choice.
To enable Wi-Fi on your iPhone:
  1. Go to the Home screen by pressing the Home button or by unlocking your phone.
  2. Touch the settings incon
  3. Look to the right of the Wi-Fi icon. If a Wi-Fi network is listed, you're all set. Otherwise, select the Wi-Fi icon.
  4. If Wi-Fi is "OFF", touch the Wi-Fi toggle to turn on Wi-Fi.
  5. Then select a network (if one is available) from the list that appears on the iPhone.
  6. When connected via Wi-Fi, you'll see a striped upside-down triangle to the right of your service provider's name on the upper-left corner of the iPhone. If there is no network available, you'll have to use the EDGE network.
i hope it will help you for further query feel free to contact.....waiting forward for your reply.....
Aug 09, 2011 | Cell Phones
I want to locate my wi fi password for my iphone.
I am assuming that you are trying to connect to the internet using the built in wifi instead of the 3G. To clarify, iphones don't have passwords for wifi. Wireless access points and wireless routers are the ones that have passwords. If you want to connect to the internet using an access point or router you must get the SSID of the router or access point and also the encryption and password to join said access point or router.
Once you have this information go to your iphone and select the settings icon. Then select the Wi-Fi, then turn on the wi-fi (if it is off), then under choose a network select "Other" and then type in the name (which is the SSID), tap on "Security", select the encryption that matches your access point or router (wep, wpa, wpa2, etc) tap on "Other network" (on the top left hand corner) to go back to the configuration page, and then type in the correct password.
Once you have done this your iphone will automatically connect to the access point or router whenever it is in range and connect to the 3G when it is out of range of the access point or router.
Hope this helps.
Aug 03, 2011 | Computers & Internet
I can not connect my i phone
From your problem description it looks like you want to connect your iPhone to your wireless home network?
Whenever you use a internet enabled application your iPhone will connect to the most recent used Wi-Fi network(access point/router).
If the last used network is not available, then your iPhone will list all available networks in range.
If you are in range of your wireless router, then it will be listed in the available networks box.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it. If needed enter a password. The password will be the security password you set on your router(WEP/WPA key).
If you do not know your password, you can read my tech article by clicking here. It will go over how to obtain your router password.
If there are no Wi-Fi networks available then your phone will use the cellular data network and fee's may apply.
Let me know if you have any other questions.
Regards,
G33k
Jun 26, 2011 | D-Link DIR-625 (790069292637) Wireless...
I need to know my password to connect my iphone ?
In case you have a protected Wi-Fi you have to use this password in order to connect your i-phone. If your Wi-Fi is unprotected (open to all) there is no need to use a password.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 27, 2011 | NetGear DG834G Router
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to use wi fi in iphone
Go to Settings > Wi-Fi and turn Wi-Fi on.
A list of networks that are in range will appear.
Select the network you want to connect to.
If the network is unsecured you will be connected.
If it is secured you will need to enter the key or password.
You will need to get the key from the person or business that owns the Wi-Fi network.
If this helps please vote for my solution.
Sep 03, 2010 | Apple iPhone 3G
I can not seem to hook my iphone up to my wifi
In order to do so you must make sure that Wi-Fi is enabled.
Devices - Wi-Fi - Click to On.
After that make sure that your network shows up on the list. When you click your network enter the password to your router. If all of these things are done correctly you will be able to connect.
Nov 02, 2009 | Apple iPhone 3G
NetGear WGT624 Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
