Question about Garmin nuvi 765T GPS Receiver
MY GARMIN NUVI 765t DOES NOT CHARGE - Garmin nuvi 765T GPS Receiver
  • 37 Answers
New battery
Posted on Aug 01, 2009
homedesigner
  • 583 Answers
SOURCE: My Garmin 765t won't power on. Anything I can do
Unfortunately, there is not a lot of easy user troubleshooting for Garmin units. I will note that the AC adapter that plugs in the USB port will give the unit more power than a USB connection to a computer or the 12vDC car adapter. If you've tried connecting it to the AC adapter and it still won't come on, it is possible the internal battery has gone bad and is consuming more power than the supply can produce to both charge and power up the unit. You can try leaving it plugged into the AC adapter for an hour or so and then trying to power it up with the AC adapter plugged in.
Let me know what you've done so far to troubleshoot and I'll research some more for you.
Posted on Feb 24, 2010
  • 4 Answers
SOURCE: garmin 765T,dont work/cant charge....
Mine did the same thing. Take a T5 torx bit and unscrew the bottom two screws. Gently pry unit apart. I used finger nails. Disconnect the battery wires from circuit board. Leave unplugged for 10 seconds. Plug the battery wires back into the circuit board. Turn unit on and then plug into computer and run the garmin web updater. Download the fix from garmin. Or you can send back to garmin and two weeks later they'll send you a refurbed unit. You'll lose all your saved data. On top of paying the shipping.
Posted on Jul 07, 2009
VOTIT
  • 2071 Answers
SOURCE: MY GARMIN 765T SAT NAV WILL NOT CHARGE.
Your Garmin is not charging then it is a loose contact or cold solder in charging socket. That is the common problem of socket you must re works the solder there or bring it to a cellphone repair if you are not electronically enclined. If re solder does not fix then problem is in the charging IC. Replaced this IC so it will charged again.
Good luck:
Don't forget to rate:
Posted on Jul 08, 2009
SOURCE: Garmin nuvi 200 pick up charger as a usb cable
I can't give you a source of the problem but I can give you at least a temporary solution. Turn the unit on without the cord attached. After it comes up, press on the battery button for 10 seconds until the diagnostic screen comes up. Plug the cord in and press Exit and the unit should work while it charges. You will not be able to use it with the computer using this method, however. To do that you need to plug it in while either without powering it on or after it is powered up normally.
Posted on Sep 02, 2009
SOURCE: Transfer "favorites" from Garmin Nuvi 660 to 765T
I had the same problem. I called Garmin and the lady said if I had the software Map Source or something, that can do the trick, but the funny thing is you have to buy the software with Map Updates, or you get the software when you buy a new unit, and register the unit within 60 days of first satellite reception. Though I searched internet and someone said to copy a certain file/folder or I'd rather just copy the whole GPS folders and that might do the trick. You are right, this is a pain in the rear end.
Posted on Jan 13, 2010
Garmin 765t can charge garmin with usb port, however, once garmin is connected to vehicle outlet, garmin will not charge and looses full charge within 30 minutes. fuse is good in vehicle, and works on...
It's most likely that the fuse in the plug of the charger lead has blown. There's a ring at the top of the charger plug. Unscrew this and the plug comes apart. You'll see the fuse inside. Be careful not to lose any parts.
Sep 27, 2010 | Garmin nuvi 765T GPS Receiver
Cannot register my nuvi 765t
Contact Gamin customer service, someone in Garmin may have type in your serial number for someone elses garmin nuvi 765t, it happens once in a while, nothing to worry about, just call Garmin and get it resolved.
Apr 03, 2010 | GPS
I tried to update my garmin. The screen doesnt move (or continue to download) I allowed for block ups.
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Dec 22, 2009 | Garmin nuvi 765T GPS Receiver
My nuvi 765 will not turn on. Any solutions? How do you reset it? Vista will not even recognize the Garmin in the USB port. I'll assume that it's because it can't communicate to the OS. :) It just shows...
Resetting the Garmin Nuvi 765T: Press and hold your thumb or finger in the lower right hand corner of the screen while powering the unit on. This will erase all USER data, base and detailed maps will remain intact.
Connect your Garmin Nuvi 765T to your computer via USB.
Download Garmin's Communicator plugin and WebUpdater, both applications can be downloaded from their site. By doing so, this will load the necessary USB drivers to your computer, allowing the Garmin Nuvi to communicate and update firmware and software via the plugin and WebUpdater.
On Vista, the Nuvi 765T appears as Garmin Nuvi without the "T" as well, (a blue triangular icon also appears) it does not affect the ability to transfer files or explore the device in any way. If you load an SD card into the Nuvi 765T, it will appear as a removeable disk and assign it a drive letter, in my case H:
Dec 11, 2009 | Garmin nuvi 765T GPS Receiver
NO POWER TO MY GARMIN 765T
Visit garmin web site for software upgrade for free also read : http://www.amazon.com/Nuvi-765T-died-tonight/forum/FxFTK8E026BG45/Tx3LG8KEDC3FWNU/1/ref=cm_cd_ef_rt_tft_tp?%5Fencoding=UTF8&asin=B001ELJER4
Jul 28, 2009 | Garmin nuvi 765T GPS Receiver
My Garmin 765T does not always work when in the cradle. Sometimes it will just saying "searching for satellite" instead of calulating and giving me the route. It also does not charge when this occurs.
Visit Garmin web site for software upgrade free ahttp://www.amazon.com/Nuvi-765T-died-tonight/forum/FxFTK8E026BG45/Tx3LG8KEDC3FWNU/1/ref=cm_cd_ef_rt_tft_tp?%5Fencoding=UTF8&asin=B001ELJER4lso read:
Jul 14, 2009 | Garmin nuvi 765T GPS Receiver
765T could not find satelites.
Charge it in your car. Then go to the Garmin website and hook the GPS up to your computer. There it will reboot your entire GPS.
Jun 27, 2009 | Garmin nuvi 765T GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
772 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
